Mk5 body on a mk6
Mk5 body on a mk6
Postby jimweb » Tue Apr 17, 2012 9:51 pm
Does anybody know if a mk5 body will fit a mk6 chassis? Thanks
jimweb
Re: Mk5 body on a mk6
Postby Terry » Tue Apr 17, 2012 9:55 pm
I think you will find that neither mk 5 or 6 has an independent chassis (barring plasma cutter skills).
Pallet Puller
Terry
Postby jimweb » Tue Apr 17, 2012 10:10 pm
Been offered a mk6 chassis cab cheap, would my mk5 Luton body not fit or a flat bed off a mk5?
jimweb
Postby Aardvark » Wed Apr 18, 2012 8:59 am
Interesting concept. You take the Mk6 with its quicker more efficient engine that bankrupts you when it goes wrong, and fit the Mk5 body that rusts while you watch. :lol:
Learning to love rust.........
Aardvark
Postby jimweb » Wed Apr 18, 2012 2:46 pm
One way to look at it, thinking more of a LEZ compliant flareside .
jimweb
Postby Aardvark » Thu Apr 19, 2012 11:48 am
If its the LEZ you're up against, then do whatever it takes. :wink:
Aardvark
Postby knighty1981 » Thu Apr 19, 2012 1:33 pm
erm.... do you want to put the box off the back of your Mk5 luton onto the back of a Mk6 flat bed ?
in which case.... yeah no problems... as long as it's the right length....
if it's the wrong length you can just adjust it to fit (shorten/lengthen bed) as long as it's not by too much
max rear overhang is 1/3 of wheel base
so if your wheels are 3m apart, then max overhang would be 1m
knighty1981
Postby jimweb » Thu Apr 19, 2012 7:46 pm
Ok thanks , so a long as I'm looking at same wheel base (ie swab,mwb or lwb) then the mk5 nd mk6 either Luton body, pick -up rear are inter changeable ? And weather it single or twin rear wheels.. Thanks
jimweb
Postby knighty1981 » Thu Apr 19, 2012 11:33 pm
you're just mounting your luton box onto the chassis rails...
even if they don;t match up 100%.... it's a piece of cake to make it fit
the chassis of the van will have a couple of bits of box section running along the top of it
so that's 2 long rails running front to back
across the top of those there'll be more steel running side to side to take the weight of the box/load...
so even if the vans are a bit different.... it's easy to make it fit :-)
knighty1981
Postby jimweb » Fri Apr 20, 2012 6:50 pm
Ok thanks for reply!
jimweb
Postby soprano1982 » Fri Apr 20, 2012 11:17 pm
Aardvark wrote:Interesting concept. You take the Mk6 with its quicker more efficient engine that bankrupts you when it goes wrong, and fit the Mk5 body that rusts while you watch. :lol:
f**king hell :lol: :lol: :lol:
soprano1982
