FAO of anyone who has installed a Cossie 24v into a Transit.
Postby dipstick » Sat Nov 04, 2006 6:35 pm
... I am trying to work out the angle of attack to get the 24v into the engine bay, where do you pick up off the motor, or do you use slings under/around the engine...?
thanks in advance... :)
dipstick
Cosworth Powered
Cosworth Powered
Postby Luke » Sat Nov 04, 2006 6:47 pm
are you fitting engine and box bolted together :?:
Postby Guy88 » Sat Nov 04, 2006 7:34 pm
Engine will not fit in with box attached. I lifetd it using some bolt on chains on hte plenum bolts lifts it square
Dont forget you need to mod the firewall by the clutch pedel :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Sat Nov 04, 2006 7:50 pm
Guy88 wrote:Engine will not fit in with box attached. I lifetd it using some bolt on chains on hte plenum bolts lifts it square
what sump did you have on guy :?:
Postby dipstick » Sat Nov 04, 2006 8:55 pm
... no the 'box is not attached, just the motor... i have used the two diag. opposed lifting eyes on the Cossie, i can get it into the engine bay, but perhaps i need to get the flywheel end down more, and the front end up more to clear the trans. tunnel and the front of the chassis...?
cheers
dipstick
Cosworth Powered
Cosworth Powered
Postby Guy88 » Sat Nov 04, 2006 9:01 pm
Mines got the standard granny sump :?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby dipstick » Sat Nov 04, 2006 9:07 pm
Guy,
Do i understand then that you removed the plenum when you dropped the motor in...?
thanks
dipstick
Cosworth Powered
Cosworth Powered
Postby Guy88 » Sat Nov 04, 2006 9:11 pm
Yes. Mines a BOA thou :wink:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Sat Nov 04, 2006 9:20 pm
guy have you got any pics of yours in the van :?:
Postby Guy88 » Sat Nov 04, 2006 9:21 pm
NO i only sat it there to measure it for the mounts. will bi in bu next week :P
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby bj928 » Sun Nov 12, 2006 9:54 pm
don't know what mount your using but i've always used the granada engine mount, and a little trick with the transit mounts, depends on the age of your transit as to whether it will work though.
bj928
Postby Guy88 » Sun Nov 12, 2006 10:05 pm
That reminds me. Big john did you put a cosworth into a J reg LWB :?:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby bj928 » Sun Nov 12, 2006 10:07 pm
no, the only 2 i've done were an L reg and an F reg, think it was an L reg may have been a J reg , can't remember what the LWB was, whys that.
bj928
Postby Guy88 » Sun Nov 12, 2006 10:09 pm
Out my way there is a Jreg LWB with smily front. had a look around it and it is cossyd. and he said a chap called John fitted the engine :?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby bj928 » Sun Nov 12, 2006 10:11 pm
no thats not one of mine, my LWB had the engine taken out and sent to a guy in Texas USA, and the van got scrapped.
bj928
