Which springs to lower back of my Tranny
Postby MattBlackMinibus » Thu Nov 25, 2010 12:27 am
Wanna lower the back end of my van.
Plan is to get some rock hard single leafs to have de-cambered.
Want heavy rated ones so I can still put weight in it without problems.
So, question is ...
what spec van has hardest single leafs which will fit my mk5 SWB?
Starting All Over Again
MattBlackMinibus
Re: Which springs to lower back of my Tranny
Postby BROWNYS V6 » Fri Nov 26, 2010 11:33 pm
what springs do you have on now :?: singles or multi-leaf :?:
BROWNYS V6
Postby MattBlackMinibus » Sat Nov 27, 2010 8:15 pm
multi
MattBlackMinibus
Postby knighty1981 » Sat Nov 27, 2010 8:30 pm
owens springs in Stockton should be able to make you some - I bought some extra leafs for my vans there after they were recommended on here :-)
if you drop them down to just one leave each, but then have a flat spring fitted under (aka a helper spring)
that way the extra spring won;t do much until you put some weight on it ;)
knighty1981
Postby Luke » Sat Nov 27, 2010 9:23 pm
the mk4 120's seem to have single leafs on them :D
Postby BROWNYS V6 » Sat Nov 27, 2010 9:33 pm
that bus i got of jono was a 120,had multi's on an was a skyrider :lol:
BROWNYS V6
Postby Luke » Sat Nov 27, 2010 10:20 pm
skyrider :lol: was a mk3 wasnt it :?:
seems to be mk4's that have the single leafs fitted the ones ive got for mine were off a 100 mk4 :D
Postby MinorMatt » Sat Nov 27, 2010 11:03 pm
twas a mk3
Postby JohnBF1 » Sun Nov 28, 2010 1:50 am
Clamp it on the stops :roll:
Or another one i saw years ago it was on a Dodge van owned by my neighbour was modified axle with some air bag system a bit like the hopping cars :D
Used to lower to the floor and rise when started :idea:
A big f-in hammer, WD40 & duck tape the perfect tool kit as recommended by sh*t Fit service technicians
JohnBF1
Postby MattBlackMinibus » Sun Nov 28, 2010 4:56 pm
JohnBF1 wrote: modified axle with some air bag system a bit like the hopping cars :D :idea:
Would be nice, but DOLLARS!!
MattBlackMinibus
Postby MattBlackMinibus » Sun Nov 28, 2010 4:59 pm
OK, so it's mk4 120 springs is it!
I really thought there'd be a great bit list of choices, knowing Ford and their Transit configuration options!
Cheers guys 8)
MattBlackMinibus
Postby Luke » Sun Nov 28, 2010 5:28 pm
mabe mk4 150's have them too :?: depends how hard a ride you can put up with :) :)
Postby MattBlackMinibus » Sun Nov 28, 2010 7:20 pm
Luke wrote:mabe mk4 150's have them too :?: depends how hard a ride you can put up with :) :)
Ooh :idea: Nice one Luke 8)
I don't mind a hard ride. I don't want problems loading it up.
(and it'll be livelier on roundabouts :twisted: )
MattBlackMinibus
Postby intransit89 » Wed Dec 15, 2010 1:14 pm
some campers have air bags works of a tyre valve on the left in side step well
i was gona fit ford carpi springs with air bags
intransit89
Postby AlanN » Wed Dec 15, 2010 1:27 pm
The mother-in-laws volvo has a monroe shocker leveling system for towing caravans fitted, jacks up and down with a switch and meter on the dash. Meant to be a off the shelf kit! Replaces the original shockers, dont about the rest of it, Ive never looked at it properly
