granada irs in my mk2
Postby BROWNYS V6 » Sat Feb 26, 2011 6:00 pm
im toying with the idea of putting a granada scorpio irs rear end up the back of my mk2 rustbucket :) need to check the width but........
the fors are;
limited slip diff
disc brakes
convert to coil over, easy to get nice an low :wink:
also my alloys that i bought to put on the mk3 will bolt straight on :D
the againsts are;
loads of fabrication :(
an i need to buy one :lol:
BROWNYS V6
Re: granada irs in my mk2
Postby Gavin » Sat Feb 26, 2011 8:27 pm
i reckon theres not as much fab as you think.
they come on a subframe that sits very tight to the car, i would be suprised if there isnt plenty of room on a tranny to create a mounting frame with some box above this and just bolt it to the spring mounts, in a similar way to how the IFS front mounts on the tranny :idea:
they have viscous diffs i think which behave a bit different, but i never had any tramp or squat problems on my granny cossie, you could throw all kinds of abuse at it and it just did its job :!:
Gavin
Postby BROWNYS V6 » Sat Feb 26, 2011 10:41 pm
weve got a sierra one at work :idea: been googling, an i might be able to fit 5 stud granny hubs on it :wink: checked the width an its pritty close so who knows :D
BROWNYS V6
Postby Luke » Sat Feb 26, 2011 10:44 pm
it's been done before :!: - on a mk5 i'm sure we've got pics on here :D
i'm pritty sure you can swap the hubs ok :D
Postby Luke » Sat Feb 26, 2011 10:48 pm
i considered it reason i didnt do it was i didnt think it's worth the hassle - the sierra/granny diffs arnt supposed to be that strong - all the big power cossys use quafe stuff (apparantly) and it then gets expensive :( also i wondered about how it would handle :? - a transit is very different to a granada and if it was crap there'd be no easy going back also it's a fair bit narrower :!: so i went for the easy option and stuck a 9" on :lol:
Postby BROWNYS V6 » Sat Feb 26, 2011 11:06 pm
hmm i did wonder how it would handle aswell,narrow track not a problem got 9" wide wheels,an dont think i'll be chewing diffs with a rover engine :lol: if i could mount it right up in back be nice an easy to dump it on the floor :D would'nt have to worry about choppin lumps out me chassis,maybe :lol:
BROWNYS V6
Postby Luke » Sat Feb 26, 2011 11:12 pm
BROWNYS V6 wrote:dont think i'll be chewing diffs with a rover engine :lol:
you never know - i only had a V6 cossy in when i thought about it :lol:
have you measured it up :?: mine are 8" wide with a good offset and i think they needed spacers - ive tried to find the info in here searched every irs post but cant find anything - i'm 99.9% sure its been done on a white mk5 was on ebay with pics :D
Postby BROWNYS V6 » Sat Feb 26, 2011 11:18 pm
no not done any measuring yet,its going round in me head at the mo :) but if i can swop hubs then i 'll use the sierra one we got at work :wink:
BROWNYS V6
Postby Luke » Sat Feb 26, 2011 11:27 pm
look forward to seeing it done 8)
do you know there are 2 types of diffs - different sizes and the mounts on the cradle are different for different sierras and one wont fit in the other :!: cant remember exactly but i found it out back in my sierra owning days :D
Postby BROWNYS V6 » Sat Feb 26, 2011 11:37 pm
yea 7 and 7 an half inch :wink: only what ive read :lol: need to get the front back together first :)
BROWNYS V6
Postby Luke » Sun Feb 27, 2011 12:02 am
BROWNYS V6 wrote:yea 7 and 7 an half inch :wink: only what ive read :lol:
yeah sounds about right :D and i think the smaller one is the LSD one :?
Postby BROWNYS V6 » Thu Mar 03, 2011 11:29 pm
just been offered an 8" ford axle off a mustang,got all new brakes on it an a slipper for £100 :D downside is its 4 stud :? an its got a 3.0 cwp in it :(
BROWNYS V6
Postby Luke » Fri Mar 04, 2011 4:00 pm
BROWNYS V6 wrote:just been offered an 8" ford axle off a mustang,got all new brakes on it an a slipper for £100 :D downside is its 4 stud :? an its got a 3.0 cwp in it :(
you can swap the halfshafts and cw&p cant you??? £100's a nice price 8)
Postby BROWNYS V6 » Fri Mar 04, 2011 9:09 pm
yea the bits are readily available for them ,and cwp's aswell :wink:an yes cheap cheap :)
an then today i got the offer of a pair of 5 stud granny hubs,straight swop for the 4 stud ones on the sierra axle we have at work,which came of an xr4x4 :wink:
i wonder if the offset on the discs is the same on both axles :? granny one is 8mm wider so i have read :) ratio in the sierra diff is 3.62 i think.
BROWNYS V6
Postby Luke » Fri Mar 04, 2011 9:14 pm
the non vented disks im pritty sure are the same as i fitted sierra ones on my escort and rememebr drilling a granada one to fit (just temprary like :lol: ) not sure if its wider cos of the vented disks??? pritty sure the granny cos had vented rears :D
anyway sod the irs get the 8" on there :mrgreen:
