Rear disc conversion!!!
Postby Gunslinger » Mon Jun 19, 2006 12:19 pm
Nice tech how to :)
so when you gonna do a twin rear wheeler ? :lol: :lol: :lol:
Gunslinger
Postby 100ps_drw_hicube » Sun Jul 02, 2006 2:00 am
Gunslinger wrote:Nice tech how to :)
apparently mk7 has discs on the drw axle :shock: :shock: :lol: :lol: might take a while to find one in a breakers :P
100ps_drw_hicube
Transit Abuser!!
Postby Luke » Sun Jul 02, 2006 10:05 am
yeah but you might be able to buy the discs calipers etc. and fith them to a mk6 axle :idea:
Postby 100ps_drw_hicube » Sun Jul 02, 2006 10:34 am
true!! so whos going to be doing it 1st :lol: :lol:
100ps_drw_hicube
Transit Abuser!!
Postby Luke » Sun Jul 02, 2006 10:35 am
they might even fit on the mk5 axle :shock: :idea: :lol:
Postby WRECKERSTEVE » Fri May 11, 2007 3:08 pm
i blagged a trw/girling cd rom from a local factor and i can put in the offset for the disc and it will give me a choice of discs i have put in 70mm slightly further in than lukes vito and 740 volvo vents pop up but i am not sure from his thread how much room there is to play with :!: but the cd saves a lot of calls and dirty hands ...... any input will be appreciated ws
you break it i take it
WRECKERSTEVE
Postby Luke » Fri May 11, 2007 5:27 pm
i think if i could have picked perfect disks the vito ones would have been mabe 10mm less - but then again if you arent using sierra calipers the offset will be different :!:
if i didnt have the problem of making the axle as narrow as possable (which you dont as your wheels arnt as wide as mine) i would have made the brackets slightly thicker set the calipers out further and just made the disks sit in the right place by fitting a packing shim behind them :D
That CD sounds handy 8) any chance of a copy :?: :D
Postby Aragorn » Fri May 11, 2007 9:21 pm
cant help with cd but http://www.brakeworld.co.uk has an online catalog that lists disk depths etc!
Aragorn
Postby WRECKERSTEVE » Fri May 11, 2007 10:06 pm
i got the disc from local lsuk not sure if the manager should of given it to me i've got to load it on the hard drive then i can e mail the file its 350mb so a copy to disc may be better :?: it has helped in matching calipers as well if its right late scorpio ran 22mm vented discs so calipers are similar to cosworth but cheaper :D i will have to strip my axle to determine the maximum depth to set the caliper bracket but i guess as far in as possible without fouling the rear leaf spring :!:
WRECKERSTEVE
Postby WRECKERSTEVE » Sat May 12, 2007 4:49 pm
i ve been down the yard today and popped of the rear hub off a similar swb van and have measured the distance from the mating face of the axle casing to the face of the flange as 80mm, the disc i found is a front ventilated disc 22 mm thick 68mm deep face 2 face and 263 diameter using late scorpio calipers (yet to aquire ) will i have enough room for the brackets, i would get ones made similar to yours luke any thoughts
WRECKERSTEVE
Postby Luke » Sat May 12, 2007 5:27 pm
what calipers are you gonna use :?: front scorpio calipers :?:
Postby Aragorn » Sat May 12, 2007 5:33 pm
surely he'll need to use rears to get the handbrake attachment?
4wd cosworths use vented rears but i dunno if scorpios do...
Aragorn
Postby Aragorn » Sat May 12, 2007 5:37 pm
checking brakeworld te scorpio rears are 20mm fronts are 24mm
cosworth rears are also 20mm
Aragorn
Postby WRECKERSTEVE » Sat May 12, 2007 6:00 pm
i getting dizzy 2 many no's :? the rear calipers off 94/99 scorpio use 20mm vented disc as you said the disc i found given i gone for 5x 108 ford wheels means the volvo discs have the same pcd i could have the disc skimmed or pad modded not sure their was 2 other options one with 72mm depth 287 dia i think these are rears the ones with internal b/shoes and 295 dia solid off rear of 740 and use standard granada rear calipers plenty about
WRECKERSTEVE
Postby WRECKERSTEVE » Sat May 12, 2007 6:06 pm
just e mailed caprisport see if any of their brackets will work you never know i understand that 1600 transit ran the famous atlas axle read this in one of the ford mags recently, could be another option haven't seen one since the mk2 was a daily driver back in the day
WRECKERSTEVE
