Luke's 24v cosworth into mk1/2 thread!!!
Postby Luke » Sun May 06, 2007 9:27 am
MrMPuk wrote:
Luke wrote:oh also forgot to say im gonna use stainless studs too :D
Stainless wont be any good, stick with HT.
why not :?:
Postby rover » Sun May 06, 2007 11:21 am
You would be forever snapping them Luke, stainless studs have no (very little anyway) tensile strength, use high tensile studs and get yourself some ceramic spray to stop them seizing up and corroding, 'off-shore' is what I use, its about a fiver a can but you wont use a full can if you put it on every nut and bolt on the van :D I've been using the same can for over two months and I use it every day!
Rover.
rover
Postby AndyG » Sun May 06, 2007 11:23 am
rover wrote:You would be forever snapping them Luke, stainless studs have no (very little anyway) tensile strength, use high tensile studs and get yourself some ceramic spray to stop them seizing up and corroding, 'off-shore' is what I use, its about a fiver a can but you wont use a full can if you put it on every nut and bolt on the van :D I've been using the same can for over two months and I use it every day!
Rover.
:idea: Stick a bit in the post for him then :P :lol:
Postby Luke » Sun May 06, 2007 12:31 pm
mabe i'll use HT then :lol: i was only thinking the stainless wont be affected by the temp, i know they arnt as strong but i thought compaired to the heat affected steel ones they would be stronger :?
sorted the gearbox - the crossmember is handed - ie the mount isnt in the middle :roll: pritty obvious really :lol:
aslo clutch cable is now fitted and wirings going in when ive finished this cuppa :lol:
Postby Luke » Sun May 06, 2007 8:47 pm
update - wireings in, so to speak, but ive still got the injector relay, fuel pump relay and the fan relay to wire up - for this i need a box mounted on the o/s inner wing :D
also ive go a problem that the servo fouls the plenum, not by a lot but enough to matter :x
so to get it running these are the jobs left to do :D
Mount coil pack
Relay box - fit and wire in
Battery - mount under seat and run wires!
gearbox crossmember - finish modding
propshaft - shorten and fit (wont stop me getting the engine running tho)
sort servo/plenum clearance problem
fuel tank?????
wire up cooling fan (allready fitted just need wiring)
finish o/s manifold and fit both of them
make up exhausts - just 2 temporary systems to get it running and MOT'd before i take them off and fit the turbos 8)
i think thats all :) so not a lot :lol:
Postby Luke » Wed May 09, 2007 5:40 pm
made a coil pack mounting bracket today :D
this will bolt to the bulkhead behind the engine and the coil will bolt to it - unfortunatly i will need to remove the plenum to get it out if the coil pack ever needs replacing :x but it does fit well there and looks neat 8)
Postby Luke » Thu May 10, 2007 9:58 pm
fitted the coil bracket today :D
also done the g/box x/member :) - but didnt have time to paint it or trial fit :(
now the relays :roll: - my mate has a Treg laguna and it has a box with 2 relays on the o/s inner wing looks perfect for what i need - problem is ive emailed everone breaking a laguna on ebay and they dont have them - so anyone know another car that has 2 vertically mounted relays in a nice neat box that would do the trick :?:
Postby custom » Thu May 10, 2007 10:51 pm
have u tried a scrappy luke theres loads of lagunas in all the scrap yards round here if you get stuck i could get u one from there and bring it to the meet if thts any help
custom
Postby Luke » Thu May 10, 2007 10:56 pm
custom wrote:have u tried a scrappy luke theres loads of lagunas in all the scrap yards round here if you get stuck i could get u one from there and bring it to the meet if thts any help
not yet - i was thinking it was not on any lagunas other than the one i saw but ive just had an email back 10 mins since and a guy is sending me a pic to confirm its the right bit :D
Postby rover » Thu May 10, 2007 11:37 pm
Why not go for a four relay box? you never know what you may want to dit in the future :!: Or is there no room? Something like a Vectra one I was thinking :idea:
Rover.
rover
Postby Luke » Thu May 10, 2007 11:46 pm
rover wrote:Why not go for a four relay box? you never know what you may want to dit in the future :!: Or is there no room? Something like a Vectra one I was thinking :idea:
Rover.
well there is the fan relay :lol: was just gonna fit that either at the other side or under the dash :? its only cos these 2 have a load of wires and would be messy to get them all through the bulkhead or i'd put them there too :(
i will look at a vectra one tomorrow as a guy at work has one :D
Postby Luke » Sun May 13, 2007 5:07 pm
progress today
still working on the relay box - bit of luck i'l be fitting it next weekend!! but ive got a lot more done tidying up the wireing :D
got my downpipes tacked together today and the brace for the o/s manifold to engine mount!! the down pipes ive just used old exhausts cut up - the n/s one is a Di front pipe and it couldnt be more suited 8) - i should at least be able to get the engine running now but more work is needed - i could do with a could of cheap silencers to fit :? i'll have to do a bit of reaserch on what would do the job ok!
fuel tank - i was wondering if the one i have on the ambilance would work - it has an external electric pump - but im not sure how the filler neck would fit with it being at the other side - i may just use the pump and forget about a swirl pot for now- just keep that tank full :?
JOBS LEFT
fuel tank?????
Postby rover » Sun May 13, 2007 6:12 pm
I cant say i've seen the fuel tank on an Amby but it will have a built in swirl pot, I'm sure you could make it fit :wink:
Rover.
rover
Postby custom » Sun May 13, 2007 7:16 pm
if its off a mark 3 ammby then it has got a swirl pot in it as thats the tank im using on my cossie, but the pump isnt strong enough it will let the engine tick over but it doesnt pump enough pressure to run properly you will have to change it im running a sierra cosworth pump and its fine
custom
Postby Luke » Mon May 14, 2007 8:43 pm
got a relay box today from the scrappys - none of the laguna ones had 2 relays like the one i saw on my mates so they were no good, but the one i got was of a vauxhall vectra i think - it has 2 relays and 2 fuses :D
only thing is the 2 fuses are very big 30amp and i dont know if i'll be able to get fuses small enough for what i need - the pump is 20amp i think that might be ok :? just gotta get up and fit it now :)
JOBS LEFT
gearbox crossmember - paint
fuel tank?????
Users browsing this forum: Baidu [Spider]
