Pictures of all available correct size pcd Transit alloys
Re: Pictures of all available correct size pcd Transit alloy
Postby nikstik » Sun Feb 20, 2022 8:04 am
Hay guys was wondering if these rims will fit my 2010 rwd swb van? I know the stud pattern is the same. I'm running the stock 16" wheels at the moment also do I need longer studs?
https://www.ebay.com.au/itm/25488287584 ... nl%3Dmkcid
nikstik
Postby wojciech » Sun Jul 03, 2022 1:48 pm
RacingLine, model B1572 BL. size 8Jx18", PCD 5x160, ET 50mm, CB 65,1, load 1.100 kg, finishing: Black (BL)
https://youtu.be/z_ZyS-LJ8hw
wojciech
Postby wojciech » Sun Jul 03, 2022 1:52 pm
RacingLine, model I0319MB. sixe 8Jx18" and 8Jx20", PCD 5x160, ET 50mm, CB 65,1, load 1.100 kg, finishing: Black Polished or Silver
wojciech
Postby wojciech » Sun Jul 03, 2022 1:54 pm
Axe Wheels, model EX35. size 8Jx18", PCD 5x160, ET 50mm, CB 72,6, load 1.050 kg, finishing: Satin Black
wojciech
Postby wojciech » Sun Jul 03, 2022 2:49 pm
MSW (designed by OZ), model MSW 48 VAN, size 6,5Jx16", PCD 5x160, ET 60mm, CB 65,1, load 1.350 kg, finishing: Black Matt or Black/Polished or Silver
wojciech
Postby Jamncream99 » Tue Sep 27, 2022 3:53 am
I can't remember the name other than Matt Black ST36. They are made in Italy, imported from the UK to Australia.
18" x 7.5" with 235/50/18 tyres.
Jamncream99
Postby wojciech » Thu May 11, 2023 9:33 pm
Supplement to the previous note (page 1) about Ronal R44
[quote="wojciech"]RONAL model R44, size 6,5Jx16", ET 60 mm, PCD 5 x 160 mm, mm, load rating 1.300kg for flat sockets and 1,150 kg for conical sockets, finishing silver or black/quote]
Note: for Transit models after 2012, Ronal in the rims changed the finish of the sockets in the R44 rims to conical ones - just like Ford did in the factory steel and aluminum rims. Nevertheless, later rims for the Mk6/Mk7 models can be installed without any problems, because there are conical nuts with M14x2mm thread available on the market. The load capacity of rims with a conical seat is 1150 kg.
The black version has arrived.
wojciech
