Rear disc conversion!!!
Postby Luke » Sat May 12, 2007 7:40 pm
yeah you were confusing me with the 22mm bit :lol:
what we'd need to know is the caliper offset too - and like aragon says you need the handbrake attacment on the caliper :D
why no copy mine vito disks and sierra calipers :D non vented tho :!:
Postby Luke » Sat May 12, 2007 8:54 pm
WRECKERSTEVE wrote:just e mailed caprisport see if any of their brackets will work you never know i understand that 1600 transit ran the famous atlas axle read this in one of the ford mags recently, could be another option haven't seen one since the mk2 was a daily driver back in the day
well - i do know the axle you have is no ware near the capri ones - ive got 2 capri atlas's and disk brake brackets for them and i had the same thought before i started mine - looking at them i didnt even need to try them on the transit one - miles different :( but i dunno about the transit 1600 one :?
Postby WRECKERSTEVE » Sun May 13, 2007 5:28 pm
caprisport couldn't help with the brackets so i'll have to borrow your design :) the caliper offset is going to have a big influence on the disc inset i guess :!: looking at the information on the cd rom i can get scorpio rear calipers to suit both vented and non vented :) without the things infront of me how can i determine this measurement :?:
you break it i take it
WRECKERSTEVE
Postby Luke » Sun May 13, 2007 6:24 pm
well if you wanna go scorpio rear i happen to have a set and i can measure them :D - but a rough guess will say they are the same as sierra :? in which case i think the offset wasnt enough by about 30mm?? :(
Postby WRECKERSTEVE » Sun May 13, 2007 6:50 pm
i have to ask but can you xplained to this ere idiot that when bolted to a plate fitted to the axle flange where will the centre of the caliper/pad gap be assuming the plate is one piece and flat does this make sense :?:
WRECKERSTEVE
Postby WRECKERSTEVE » Sun May 13, 2007 6:55 pm
as i mentioned i have measured 80mm from face to face and the caliper will be placed above disc and am i right out towards wheel so i will have a amount over that will give me a figure of the best offset without any bends in i can then brace this off axle tube :?:
WRECKERSTEVE
Postby WRECKERSTEVE » Sun May 13, 2007 7:03 pm
2wd cosworth and late scorpio have the same part no in trw info :)
WRECKERSTEVE
Postby Luke » Sun May 13, 2007 7:06 pm
look up vito rear and see what the cd says the offset is :D - the disk thickness is 10mm :!:
then we can work it from that :D
Postby WRECKERSTEVE » Sun May 13, 2007 7:57 pm
luke the vito disc for all variants is 65 mm deep from face to face with a thickness at the flange end taken out and 5 mm half the friction part of the disc this will tell how mush more or less offset is required to line caliper up with axle face and keep bracket simple :) the only thought is that going for 22 mm discs and relavant calipers is the piston end the same thickness and the extra width carried across the bridge part of the caliper and likewise the disc i will check depth of scorpio disc and compare :idea:
WRECKERSTEVE
Postby WRECKERSTEVE » Sun May 13, 2007 8:03 pm
scorpio rear dics are 10mm thick 33 mm deep solid 20mm thick 43 mm deep vented :?
WRECKERSTEVE
Postby Luke » Sun May 13, 2007 9:01 pm
scorpio disks could be made to fit - there not too far out :D
but......................... do you want scorpio disks your pcd isnt 112 - what disks do you nwant to use that are the same 20mm thick but suit your 108mm pcd :?:
Postby WRECKERSTEVE » Mon May 14, 2007 12:51 am
with cd rom i got i put 5x108 and it shows all the discs of that pcd 8) you tell me the magic number to suit the calipers and i will find the nearest to that figure :) steve
WRECKERSTEVE
Postby WRECKERSTEVE » Mon May 14, 2007 9:41 pm
have you any measurements yet :wink: and i can copy the disc and have it on file if need it
WRECKERSTEVE
Postby Luke » Mon May 14, 2007 10:20 pm
havent got the measurments yet - my scorpio is with my van and it dont live with me :( i only get to see it at weekends :lol:
Postby WRECKERSTEVE » Mon May 14, 2007 10:38 pm
get a better lawyer :lol:
WRECKERSTEVE
