Mk1 and 2 independant front suspension conversion!
Postby AndyG » Sun Mar 04, 2007 1:24 am
Luke wrote:
Andyg wrote:What year are your 120 springs from :?: Van or Bus :?:
van 94 :D
Mmm :!: Yellow/White :?: :wink:
Postby Luke » Sun Mar 04, 2007 1:30 am
Andyg wrote:Mmm :!: Yellow/White :?: :wink:
well they were brown/rust but ive since shotblasted them and there now black :lol:
have you got a list of all the colours - Lbs :?: or have we been thorugh this before :? :lol:
Postby Luke » Sun Mar 04, 2007 5:55 pm
update- well its all fitted and the vans back a rolling & steering shell :D
i think i took too much off the springs :( 6" clearance on the front spoiler :shock:
my mate looked at it and said it was spot on but im not 100% sure in hindsight i'd have left a ¼ coil more on the spring :roll: :lol:
i should get some pics up soon, only problem now is i cant fit my front alloys on so i need to sort the hubs some how, but i'll look at that during the week :? i really dont want arches on :!: but i may have to roll the existing ones to get clearance :!:
Postby RAD » Mon Mar 05, 2007 9:36 pm
THat looks like a serious amount of work youve done there!
RAD
Postby Luke » Wed Mar 21, 2007 12:05 am
been looking at the clearance problem today and i think the only option is have some hubs made :shock: also im gonna have to swap to a different disk too, i think, one thats front mounted with a very small offset! ive been looking through the catalogues and mercedes seems a good one to go for, but the closest ive got the o/d to is 275mm and if i upgrade to lwb calipers it will be 270mm :? i could allways machine a skim off the disk but i like to keep replaceble parts standard :D also the disk thickness is 22mm and the transit is 24mm same catalogue :?
Postby Sundowner » Wed Mar 21, 2007 9:32 am
Hey luke how far do you nee to go back?
Can you machine it off the wheel?
Sundowner
Postby Luke » Thu Mar 22, 2007 12:00 am
Sundowner wrote:Hey luke how far do you need to go back?
about 20mm
Sundowner wrote:Can you machine it off the wheel?
not really see above :( :lol:
but seriously......... i could mabe take a skim off the wheel and alter the existing hub slightly both together may get enough clearance - mabe use the mk1 hubs as they dont stick out as far :? :D
Postby Luke » Sun Mar 25, 2007 3:27 pm
just measured and its ideally 70mm (35mm each side) i need to go in :x
Postby Aragorn » Sun Mar 25, 2007 9:23 pm
got any pics of the finished work?
are you gng to redrill the mk4 hubs? is the redrilling gonna be easy enough?
Kev
Aragorn
Postby Luke » Sun Mar 25, 2007 9:30 pm
Aragorn wrote:got any pics of the finished work?
Kev
i will get round to taking some photos, and unfortuatly i cant redrill the mk4 hubs as they stick out too far :( if i'd done it on a mk3 the mk1 hubs would have fitted by the looks of it and made it narrower - ive redrilled them and they redrill fine - mk4 is a little trickyer but i still think they would redrill especially a larger pcd say bmw or jag :D
ive got a granny cossy disk today and im gonna have a play around and see if i can somehow mount that on the transit hub and give me the clearance i need :D
Postby transitgeoff » Sun Mar 25, 2007 9:33 pm
maybe better to just shove the bm or jag front lot up from start :?:
transitgeoff
Postby Luke » Sun Mar 25, 2007 9:46 pm
transitgeoff wrote:maybe better to just shove the bm or jag front lot up from start :?:
mabe :? but if it wasnt for the alloys the job would be done now :D
also jag is a bit too narrow i measured one up before i started - bearing in mind ive got the alloys i want allready, but tbh i quite enjoy working round these problems keeps my mind active :lol:
Postby Aragorn » Sun Mar 25, 2007 9:49 pm
sorry for semi hijack. whys the mk4/5 hub more difficult ? it a different shape?
will mk3 hub fit mk4/5 stub axle?
cheers
Aragorn
Postby Luke » Sun Mar 25, 2007 9:52 pm
Aragorn wrote:sorry for semi hijack. whys the mk4/5 hub more difficult ? it a different shape?
cheers
mk3 wont fit mk4/5, i think mk3 will fit mk1/2 but im not 100%, the mk1/2 hub is totally flat whereas the mk3/4/5 hubs have recessed areas in making it a little more difficult to locate a stud :D
Postby carnut1100 » Thu Jun 21, 2007 5:02 am
I love this conversion, and I would like to do it on our Mk1.
What years are Mk3s? I know bugger all about anything post-Mk2.
If mk 1/2/3 hubs are interchangeable, then I can just fit my Falcon hubs from the disc conversion tht is on the beam axle. It uses Transit bearings and keeps the same track as a mk1. Vented discs with 5x112 PCD too......
Gotta start looking for a Mk3 methinks.........
1979 Mk2 Truck Project thread here
carnut1100
