Rear disc conversion!!!
Postby Luke » Tue May 15, 2007 9:32 pm
right got it today the measurment to the mounting face of the granada scorp caliper to the back of the disk was 23mm
so - it the transit one is 80mm (did you say) from the back to the front then 80 - 23 =57mm thickness disk req'd :D
so whats 57mm then????
and 1 more thing i fogot about if you are redrilling less than 112 check that is isnt too small for the hub bearing :!:
Postby WRECKERSTEVE » Tue May 15, 2007 10:39 pm
vw camper85/92 57mm to suit 5x112 that would suit your fitting disc is slightly thicker u can go either way for my 108 pcd waiting on the engineering co to advise if i can do this :!: if they can a espace disc will fit :)
you break it i take it
WRECKERSTEVE
Postby Luke » Tue May 15, 2007 10:54 pm
if you look at these they are 112mm - not much room left :shock:
Postby WRECKERSTEVE » Tue May 15, 2007 10:58 pm
2mm or 4mm in close any other thoughts except changing the axle :?: :(
WRECKERSTEVE
Postby Luke » Tue May 15, 2007 11:04 pm
if mine were off the van i could measure them :)
at the time i was just glad they fitted in so didnt bother seing how much smaller i could have got :)
Postby WRECKERSTEVE » Fri May 18, 2007 11:04 pm
wanted to stay with the ford wheels but as you know the front hubs are also giving problems so its bmw wheels and redrilled hubs or a big hammer and plenty of filler :evil:
WRECKERSTEVE
Postby Gunslinger » Mon May 21, 2007 12:11 pm
if you need somewhere to upload that 350mb cd, then you can put it into my RapidShare account as i plan on keeping that for a while and then it will be available for download if needed.
i'm sort of offline at the moment (broke my main pc at the moment) only accessing from work or spare pc, but i have none of my usual files bookmarks or passwords at the moment, pm me if your interested and when i'm back online full time we'll sort something out
Gunslinger
Re: Rear disc conversion!!!
Postby Luke » Sat Mar 15, 2008 4:43 pm
well to update this ive just fitted an inline regulator to the back brake line :D
very dissapointed :evil: still locks the rears and now holds them on for a few seconds after you lift the pedal :x
i got it off ebay was only a cheep one well £40 :shock: but ive cut the lines, made a mounting bracket etc. looked a tidy job but not much good if it doesnt work :roll:
Postby Guy88 » Sat Mar 15, 2008 4:45 pm
Luke wrote:well to update this ive just fitted an inline regulator to the back brake line :D
Could you net fit a LAV :idea:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Sat Mar 15, 2008 4:47 pm
i'll find the seller and post it up here - i'd have left negative feedback but it was over 60 days ago :(
i was expecting this to give me the same effect - just a lot neater :D ive fitted it on top of the servo :D
Postby Gunslinger » Sun Mar 16, 2008 5:11 pm
load apportioning valves are dreadfully unreliable, the symptoms you have now luke may not be a faulty regulator, more a symptom of the way it works, as an inline regulator cant vary the pressure, so while it locks when empty it maybe fine when loaded (kind of like the LDV syndrome :P )
i'm afraid the only method i know of that will work is an abs setup just for the rear wheels, because of the varying pressures required depending on load
Gunslinger
Postby Terry » Thu Mar 20, 2008 11:44 am
Dunno if its any help, but the vented discs on Scorpios are on the Cosworth & Estate variants.
The Escort Cosworth is the same part too, callipers obviously all the same, prone to siezing the stupid handbrake
(excuse technical term) lever thingy.
H.T.H.
Terry
Pallet Puller
Terry
Postby Terry » Thu Mar 20, 2008 1:17 pm
Sorry about that last post only read up to page 8 before I butted in.
If you still have locking rears try harder pads (assuming you can get them !).
If you are determined to keep the discs what about twin master cylinders ,
split front/rear with a balance bar ?
Pallet Puller
Terry
Postby BROWNYS V6 » Thu Mar 20, 2008 11:52 pm
luke have you seen the adjustable valve that fits in the pipe to the rear brakes allows you to regulate the pressure :?:
had one on my mk2, did the job :wink:
BROWNYS V6
Postby Luke » Thu Mar 27, 2008 3:30 pm
i just got an email back from the suppliers they say it shouldn't be like it is and ive got details of how its piped - just incase it was marked wrong and they will refund or replace it :D
as ive made a neat little bracket and altered all the pipework i'll get a replacement :D
and yes i'm determined to keep the rear disks :lol: i wasnt too bothered about perfecting it as i'll proberbly be changing the whole axle over for a non transit lsd one later and i dunno yet what brakes that will have but i just wanted to stop the dangerous rear locking problem for the time being :D
