knighty1981 wrote:can't you get the same engine, with a bosh pump and no electrics from an earlier citron ?
loads of people on the veg oil forum run them, because they run happily on pure veg oil
if you ask on there, those guys know those engines inside out - http://www.vegetableoildiesel.co.uk
iirc you can also get the newer 2.1 lump, and swap the injector pump and injectors from a 1.9 onto it and toss all the electrics away
oldskooler wrote:was it a pd twin cam (01 0n) tdi you measured?? what we talking from the back gearbox mounting face to the front of the crank pulley.......bout 19 or 20 inches?????? i never got chance to get to the breakers with the tape!!!![]()
For a 1,9 swap you need use an adapter plate between the engine and tranny as the 1,9 4cyl bolt pattern is not the same as the 5 or 6cyl ones.
Luke wrote:ok that wont work he says in the threadFor a 1,9 swap you need use an adapter plate between the engine and tranny as the 1,9 4cyl bolt pattern is not the same as the 5 or 6cyl ones.
dieselhead123 wrote:Luke wrote:ok that wont work he says in the threadFor a 1,9 swap you need use an adapter plate between the engine and tranny as the 1,9 4cyl bolt pattern is not the same as the 5 or 6cyl ones.
Looks like you have just saved yourself £300 mate![]()
Mt75 and an adapter plate it is then?
Cheap readily available gearbox, easy speedo connection and you could 'spin' the engine ao as to put it 'up-right'.
it's looking that waydieselhead123 wrote:Mt75 and an adapter plate it is then?
