not sure about the quenching in oil bitWRECKERSTEVE wrote:luke you could varify this point possibly the hub is a forged component and can be welded as long as it is quenched in oil as you do each recess to maintain as near as possible the grain structure and because the loading across the flange is uniform and thro 5 points it should be ok
Aragorn wrote:steering knucles on novas are most certainly cast iron, same setup is used on corsas too
as are renault clio ones
and ive seen clio one shattered after a hard collision with a kerb
anyway back to the original point:
if you positioned the stud im middle of the recess, it'd be no different to the stud being mounted thru the normal part of the hub, as they're both about the same thickness, and theres no real side loading on the studs anyway so the part going thru the unsuppored area is irrelevant and would just be like fitting a spacer to a normal alloy?
Aragorn wrote:if you positioned the stud im middle of the recess, it'd be no different to the stud being mounted thru the normal part of the hub, as they're both about the same thickness, and theres no real side loading on the studs anyway so the part going thru the unsuppored area is irrelevant and would just be like fitting a spacer to a normal alloy?
problem with that is there is nothing supporting the bit which holds the stud- also the studs could bendAragorn wrote:just leave the recess where it is?
thats not a bad ideaSundowner wrote:Instead of drilling/machining for wheel studs/nuts why cant the hub be drilled and tapped for wheel bolts?
How thick is the hub in the recessed area, woud it be thick enough to drill/tap?
yep thats trueAragorn wrote:the 'unsuppored' length is no different to the section of stud that would pass thru a wheel spacer for example
yeah can do that now im back at work and the hub is there nowAragorn wrote:i still think using the brake disk holes is a viable option, can u possibly measure their exact pcd? im thinking its either 100 or 101.6mm with 10mm drilling
