modifying the atlas axle
Re: modifying the atlas axle
Postby Chug » Tue Jan 11, 2022 12:19 am
Good to see you are making progress too :mrgreen:
will the old holes in the hub get welded up or just left?
what size tube you looking for in case I come across any?
Chug
Postby BROWNYS V6 » Tue Jan 11, 2022 7:59 pm
cheers mate, old holes will be gone as were going to turn the hub down eventually, will need to pull the van apart to measure the inside of the rear discs(merc vito :wink: ) then we can turn them down, the tube i need is 73mm od and 58mm id with an 8mm or 10mm wall thickness and we should be able to machine it to marry the 2 together (i think) :lol:
cheers :)
BROWNYS V6
Postby BROWNYS V6 » Tue Jan 25, 2022 9:47 pm
Test
BROWNYS V6
Postby BROWNYS V6 » Sat Feb 05, 2022 11:49 pm
so ive had a bit more machining done, halfshafts have been reduced in diameter, i decided to use a pair of 5 series bmw rear brake discs i had in stock, rather than take the van apart to get measurements of discs im already using, means we wont need to change the pcd in the discs either as they are 5x120 already :mrgreen:
ive welded some rings onto the shafts, as a spigot ring to help locate the wheel, and also it will take some stress off the wheel studs hopefully, as its a 9 1/2 x 17 rim we will be running :mrgreen: we still need to get the ends welded on the axle tube, but finding it hard to get some tube/hollow bar to get the two to marry up, and then we can get the shafts cut to length and resplined 8)
more soon
BROWNYS V6
Postby Chug » Sun Feb 06, 2022 12:58 am
You're getting there then Paul, I did think of your tube when I went to my engineer mates recently, he had a look and but nothing that big and he says its a weird size and you will have trouble finding it and maybe insert plugs of steel like fingers all round and weld over?
Chug
Postby BROWNYS V6 » Sun Feb 06, 2022 8:28 pm
yes mate still chipping away at it, yeah i am struggling to find the right stuff, think im gonna end up buying a big lump of solid and getting it machined to suit, gonna be a ballache me thinks
cheers dude
BROWNYS V6
Postby BROWNYS V6 » Sun Feb 13, 2022 2:14 pm
BROWNYS V6
Postby BROWNYS V6 » Mon May 23, 2022 10:47 pm
really need to get back on this and get it done, fukin square tube transit axles are made of chocolate i rekon, load of sh*t,
i got me a nice chunk of billet steel to marry the 2 bits of axle back together, jus need my engineer to get his lathe spinning :mrgreen:
more soon
just hope that shitty square tube axle holds out
:roll:
BROWNYS V6
Postby BROWNYS V6 » Sun Jan 08, 2023 12:18 pm
So I'm back on this yesterday, halfshafts came backfrom engineers, just need to to get ends resplined to atlas spec, but need to get axle ends done first, managed to find a big enough chunk of steel to marry up the square tube ends to the round tube case, with the engineer now, had to bare metal the axle case again, as its gone rusty then decided to give it a squirt of epoxy primer
More soon
Ps the shitty square tube axle didn't last. I had to swop the axle off the van for my spare atlas, trouble now I'm running odd wheels
:evil:
BROWNYS V6
Postby BROWNYS V6 » Sun Jan 22, 2023 8:29 pm
so my bits came back from my engineer, i now need to take some measurements off the van, and get my 91/2 x17 rims spot on in the arch between the inner and outer, as it is a very tight fit, my big chunk of steel is getting smaller, think most of it will end up in the engineers bin by the time were done :lol:
more soon
BROWNYS V6
Postby Chug » Sun Jan 22, 2023 11:20 pm
I bet your big lump of steel wasn't cheap either! keep up the good work :D
Chug
Postby BROWNYS V6 » Sat Jan 28, 2023 12:00 am
i think it was about £30, yeah a bit gutted that most of it will end up in the scrap bin, but if it gets the axle back together, then its all good.
bought another pair of new wheel bearings the other day, and managed to find a new pair of ford lock washer tabs, just need to find a new pair of hub nuts now.
more soon
cheers
BROWNYS V6
Postby BROWNYS V6 » Tue Jan 28, 2025 6:35 pm
so a bit more progress on this if anyone is interested, the axle is under the back of the van, ends are tacked in position, we will be running my de cambered springs, so ive chopped off the spring perches as the pinion angle was wrong after the decambering, those have since been re tack welded in place, i will try and put a pic on, but they always seem to upload sideways :roll:
more soon
:wink:
BROWNYS V6
