bad boy bonnet
Re: bad boy bonnet
Postby Gurj51ngh » Thu Jul 31, 2008 9:31 pm
can you do 1 for a mk6 transit???
Gurj51ngh
Forums Loudest Van!
Re: bad boy bonnet
Postby MrMPuk » Thu Jul 31, 2008 9:35 pm
Gurj51ngh wrote:can you do 1 for a mk6 transit???
Unlikely as the bonnet doesn't go round the lights like the Mk5.
Re: bad boy bonnet
Postby MONSTER 0NE » Thu Jul 31, 2008 9:44 pm
im gonna do my own for my van as i aint gonna get ripped off that way :evil: and i then know its been done well and not a bodge job
MONSTER 0NE
Re: bad boy bonnet
Postby custom » Thu Jul 31, 2008 9:48 pm
yes i could do one for a mark 6 but you would have to extend the bonnet down over the grill
custom
Re: bad boy bonnet
Postby intransit89 » Thu Jul 31, 2008 10:13 pm
my thinking is best to use a
cardboard cut of your headlight shape so
you can get your template right then get a clamp and clamp it to your bonnet then get a ruler and draw a line where you going to have it so it lines up end of the bonnet nere to your ind to the end of the head light next to your gril then put it on some sheet of
steel then cut out your shape then use a wire
brush on your grinder to get the paint of the bonnet
where you gona weld your template steel on then clamp your steel on and make it flush and weld it on then grind the welds down so its all flush then get some filler :D
but thats my plan :wink:
now looking at it its not much steel as i throught it would be so its just looks like its made the shape of the head light strighter but looks mint for just to say its about 20cm ish x 7cm ish of steel 8)
intransit89
Re: bad boy bonnet
Postby Gurj51ngh » Thu Jul 31, 2008 10:18 pm
hi mate, if you have a look at the mk6 head lights you will see that the top section about 25mm roughly has a slight angle, this angle then runs flush in with the top section of the grill. so i was wondering if you could make the bonnet just go over that angel over the headlights it wouldn’t even have to go over the grill.
its a bit like the mask the mk6 comes with like the wrt van just on the top of the head light though not all over. i will post a pic soon. cheers. :D
Gurj51ngh
Forums Loudest Van!
Re: bad boy bonnet
Postby custom » Thu Jul 31, 2008 10:32 pm
im sure i cud do that mate
custom
Re: bad boy bonnet
Postby Guy88 » Thu Jul 31, 2008 10:40 pm
Dangerous did mine
Passed the MOT
Piece of pi$$ to do aswell
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: bad boy bonnet
Postby intransit89 » Thu Jul 31, 2008 10:46 pm
Guy88 wrote:Dangerous did mine
Passed the MOT
would 2mm be ok as to use 1mm might not be good :?:
intransit89
Re: bad boy bonnet
Postby MrMPuk » Thu Jul 31, 2008 10:47 pm
Passed the MOT
1.5mm :wink:
Re: bad boy bonnet
Postby Guy88 » Thu Jul 31, 2008 10:47 pm
Passed the MOT
iirc mine was 1.5mm
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Re: bad boy bonnet
Postby intransit89 » Fri Aug 01, 2008 12:25 am
MrMPuk wrote:
Passed the MOT
1.5mm :wink:
thanks mike :D
will get some new clean 1.5mm then only want a small bit so might go to this metal place nere me who has cut ofs for the skip :wink: :D
intransit89
Re: bad boy bonnet
Postby thehangmen » Fri Aug 01, 2008 12:28 am
Couldn't you just bolt a plate on from the inside and then use fibreglass and filler to get it flush with the front?
thehangmen
Re: bad boy bonnet
Postby intransit89 » Fri Aug 01, 2008 12:42 am
thehangmen wrote:Couldn't you just bolt a plate on from the inside and then use fibreglass and filler to get it flush with the front?
you could do mate but i bet at some time or a other it will get nudged and then the fibreglass / filler will have a crack at the end of the plate joint i would just weld it then its done to be save side :wink:
intransit89
Re: bad boy bonnet
Postby Gurj51ngh » Fri Aug 01, 2008 5:21 pm
MONSTER 0NE wrote:im gonna do my own for my van as i aint gonna get ripped off that way :evil: and i then know its been done well and not a bodge job
Gurj51ngh
Forums Loudest Van!
