roof mounted monitors
Re: roof mounted monitors
Postby Luke » Sun Nov 09, 2008 6:25 pm
executivetravel wrote:but cannot find any 1" sq end caps
what these :?: (btm right)
http://www.rswww.com RS Stock No. 621-764 :?
Postby executivetravel » Sun Nov 09, 2008 8:05 pm
dunno, i think plastic trunking has end caps (B&Q) or a short length of 1"x1" ally angle across the ends would tidy it up/cover the holes.
executivetravel
Postby executivetravel » Sun Nov 09, 2008 8:11 pm
executivetravel
Postby Luke » Sun Nov 09, 2008 8:19 pm
yeah same but the RS ones are flat and only 75p for 12 :D
i'm sure you could find them cheaper as RS arnt cheap :lol:
Postby executivetravel » Sun Nov 09, 2008 8:34 pm
if i see any square tubing chairs ill be fine....
executivetravel
Postby AndyG » Sun Nov 09, 2008 10:37 pm
Postby executivetravel » Mon Nov 10, 2008 1:58 pm
probably are but only need a max of 4 ill hunt around
executivetravel
Postby executivetravel » Mon Nov 10, 2008 8:17 pm
I thought two strips of polished and varnished hardwood could look better than shiny aluminium and wouldnt need endcaps!
and B&Q sell em
ive bought a 5" motorised screen all singing all dancing dvd/usb/single DIN unit and a transit facia adaptor
i thought the 7" would be a bit too much maybe
executivetravel
Postby executivetravel » Tue Nov 11, 2008 1:31 pm
first job, modify the facia plate, its a bit too curved for the dvd player
next to search for some extension leads for the outputs/inputs...
executivetravel
Postby custom » Tue Nov 11, 2008 1:46 pm
maplins sell the leads you need mate and quite cheap
custom
Postby executivetravel » Tue Nov 11, 2008 2:51 pm
humpf
id forgotten ford put damn silly aeriel plugs on the leads into radios
damnit
executivetravel
Postby MrMPuk » Tue Nov 11, 2008 2:52 pm
executivetravel wrote:humpf
damnit
The adaptor lead kits normally come with an extension for the aerial plug.
Postby executivetravel » Tue Nov 11, 2008 8:54 pm
£2 for an adapter off ebay
all the in/out/vid/audio/spkr leads have the same female end, is that a RGB plug/socket?
10 all together, main stuffs ok on its din block multiplug
executivetravel
Postby MrMPuk » Tue Nov 11, 2008 9:02 pm
executivetravel wrote:all the in/out/vid/audio/spkr leads have the same female end, is that a RGB plug/socket?
No, they are RCA.
Postby executivetravel » Tue Nov 11, 2008 9:20 pm
yer....
just ordered a 5m cable so i hope they are.....lol
15" drop down monitor purchased off fleabay too
all the bits are coming together.......lol
executivetravel
