8 spoke steel wheels
Postby rover » Thu Mar 23, 2006 11:49 am
maxlee wrote::cry: dam not owning a posh van i got to spend money on fixing mine up befor i can even look at wheels or tho i do have some 109 land rover wheels :lol:
And mines a posh van? 1989 F reg= Not posh :lol:
Rover.
rover
Postby woody » Thu Mar 23, 2006 12:41 pm
THATS RIGHT MATE US WITH THE 1989 F REG, POSH !!! VANS SHOULD STICK TOGETHER, EVEN THOUGH IT MIGHT BE WITH STRING DUCK TAPE AND CHEWING GUM :lol: :lol:
TRANSITMENTALDEDICATION
woody
Postby john.E » Sun Apr 16, 2006 11:58 pm
did anyone ever hear of "us wheel" they do the steel 8 spokes and modular wheels and a few other types the thing is they have huge range of sizes and fitments and im sure theyed have a fitment to suit transit 5 stud and 6 stud axles?if you google "us wheel" youl get the site,what is the fitment of 5 stud and 6 stud axles any way?
"you say culchie like its a bad thing"
john.E
Postby rover » Mon Apr 17, 2006 12:23 am
The 'Blade' is available in 6x6.5, which is 6stud x 6.5" PCD which is 165mm, so they would definately fit the 6 stud transits. :D
unfortunately I couldnt find any 5 studs at all that have the same PCD.
Rover.
rover
Postby MrMPuk » Mon Apr 17, 2006 12:25 am
The PCD is 160mm, there doesn't appear to be any vehicle other than Tata that uses this PCD but you never know there might be something in America that uses it. America use Feet and Iches so if you are looking at American wheels you need to look for a PCD of 6 5/16 inches.
Postby MrMPuk » Mon Apr 17, 2006 12:28 am
rover wrote:The 'Blade' is available in 6x6.5, which is 6stud x 6.5" PCD which is 165mm, so they would definately fit the 6 stud transits. :D
Rover.
Typing at the same time there Rover, 165mm is the Land Rover fitment so I don't think those ones will fit.
Postby rover » Mon Apr 17, 2006 11:39 am
Jees what was I thinking at halfpast midnight :oops:
I know Transits are 160 PCD :roll:
Rover.
rover
Postby Lightweight Nat » Sun Apr 23, 2006 1:26 am
Rover.
Land Rovers are 5 stud, so those wont fit land rovers either :lol:
Cheaper than Grittish Bass
Lightweight Nat
Postby UK_ANDY » Mon Jun 05, 2006 1:37 am
anyone tryed here ???
http://stocktonwheel.com/
old ford's never die they just go faster
Click here to vote for the forum in the Ford top 50 sites!!
UK_ANDY
Postby bob cratchit » Tue Jun 06, 2006 3:57 pm
WHere can i get hold of some 'jellybean', slotted mag wheels for a transit, i'd like to go 'old skool..... 8)
bob cratchit
Postby UK_ANDY » Tue Jun 06, 2006 5:53 pm
check here http://stocktonwheel.com/ under new products looks like this company is about to start manurfacturing slot mag's!!! dont know what shipping would cost from the usa ?
UK_ANDY
Postby bob cratchit » Tue Jun 06, 2006 6:24 pm
ho ho ho...superb, there's loads of belting looking wheels there!!......might need more than one van for all the wheels i like!!! :D
bob cratchit
Postby Luke » Tue Jun 06, 2006 6:25 pm
bob cratchit wrote:WHere can i get hold of some 'jellybean', slotted mag wheels for a transit, i'd like to go 'old skool..... 8)
get some jag or similar - any so long as its 5stud and look at my post in tech how toos :D
Postby UK_ANDY » Tue Jun 06, 2006 7:55 pm
A few years ago i worked in a foundary as a furnace man most of the alloy we used was recycled often we woild get loads of old alloy wheels, we x-rayed a number of wheels just as a matter of intrest out of 10 wheels we x-rayed only 2 showed no sign of stress cracking , the most common place this showed up was around the stud holes ,one wheel in paticular comes to mind ,a cobra superslot which had been re drilled to a diffrent pcd larger than the origonal 4 of the 5 stud holes had cracked right through to the edge of the wheel centre . If you are going to use old alloys get them crack tested first avoid redrilled wheels where the stud holes are close to the edge of the centre. On 5 stud slots the stud holes should be drilled inline with the centre of the spokes. Wolfrace used a diffrent center patern for land rover ,transit ,some 4x4 and some vw applications with larger pcd,s
UK_ANDY
alloys
Postby darktransit » Wed Aug 16, 2006 10:06 pm
Hi all i have these 5 spoke alloys on mine...
darktransit
