now for the rear does the brake shoes and brake cyls fit from the 6 stud fit the 5 stud axel if so will the new hand brake cable i put on fit the 5 stud as well if so i will swap the new parts over from the 6 stud axel to the 5 stud axel
and to fit the 5 stud axel i was thinking of undoing the u bolts on the springs and keep the 190 springs and just bolt the 5 stud axel stright on with the shocks still on the 190 chassis and the shocks will go back in at the bottom where the shock bushers bolts go on and then connect the prop back up job done
oh and keep the brake pipes on just undo from the brake cylsd and leave the brake pipe hanging there fron the load componsater as i will use the one on the van as dave said if i use the 120 one of the blue van it might fook things up as in if i keep the load valve on the 190 and springs should be ok its basicly just the drive train wait iam changeing as iam a snob and want alloys
