lowered transit springs
Postby Luke » Mon Apr 24, 2006 9:59 pm
i get you - axle on top of the springs!!! :lol:
I'd be very interested to see some photos and see how looks - its a fair drop must be 5-6" :)
i take it the c-notch bits for the chassis are to raise it back a bit after the drop :?: :?
:D
Postby el_tel » Mon Apr 24, 2006 10:01 pm
lol i mean springs under the axel!!! better put the beer back in the fridge!!!
el_tel
Postby el_tel » Mon Apr 24, 2006 10:07 pm
c-notch= got to put a bit in the chassis so the axel can sill move as theres about half inch of room , yea the drop will be about 4ana half to five
el_tel
Postby Luke » Mon Apr 24, 2006 10:11 pm
el_tel wrote:c-notch= got to put a bit in the chassis so the axel can sill move as theres about half inch of room , yea the drop will be about 4ana half to five
like it 8) what about the shocks are you gonna raise the mountings too :?:
Postby crazyscoot » Mon Apr 24, 2006 10:18 pm
any chance of "in progress" pic's?
Negative reality inversion
crazyscoot
Postby el_tel » Tue Apr 25, 2006 6:51 am
yea will be taking pics as im doing it!!! yeah gotta move the dampener brackets
el_tel
back axle
Postby midniteclassix » Tue Apr 25, 2006 8:54 pm
you will need to remove spring saddles that go UP to the spring put axle on top of springs then weld them back on them you can use spacers to lower even more if requerd but remember as i think thin the diff is set at 4 degrees down i think you will have to check before removeing
old ford never die THEY JUST RUST AND FALL APART
midniteclassix
Postby express post » Tue May 02, 2006 11:09 am
i have just had my 97 lwb lowered they did the front spring and cut the bump stops.it drop about 60mm now the steering rods are straight they told me not to go lower because it stuffs up the steering.and the loweres the rear the same on standed springs if i want to go lower on the rear i have to get custom spring made with upside down loops but they may hit the chassis rail
express post
Postby maxlee » Wed May 03, 2006 10:10 am
express post wrote:i have just had my 97 lwb lowered they did the front spring and cut the bump stops.it drop about 60mm now the steering rods are straight they told me not to go lower because it stuffs up the steering.and the loweres the rear the same on standed springs if i want to go lower on the rear i have to get custom spring made with upside down loops but they may hit the chassis rail
pics? :D
maxlee
Postby belly » Wed May 03, 2006 7:50 pm
i love slammed vehicles my car is -60mm all round but will a lowered van attract unwanted attention thinking its overloaded i know they cant do you cos its not !!i just mean the hassle :(
belly
Kaiser Chief
