2.5di engine in a Mk 6 transit rwd van
Re: 2.5di engine in a Mk 6 transit rwd van
Postby pat stevens » Sun Feb 13, 2011 10:58 pm
i agree with you there i had a durotorque in a (dare i say it) 54 reg ldv convoy i bought it cheap £750 after a month the thing started blowing horendous amounts of smoke without notice totally shagged i know that they used to run the old transit engines in these vans with no trouble so power and all that shouldnt be a problem ,just a bit of fabrication here and there ,ive seen a few with rover v8s in one verry well done example recently for sale on ebay if you can get a mk6 cheap enough and youve got a rotten mk5 what have you got to lose ,if it goes wrong break the van recover your money from parts be nice to see it done good luck
if its got tits or wheels its always gonna end in trouble !!!
anyone can restore a van but it takes a real man to chop it up !!!
pat stevens
Postby gandy » Fri Feb 18, 2011 10:18 pm
hi just reading this now has anyone on here done it yet because i have just started doing my 51 plate 90/330 rwd now i have got the di engine in just need to sort out the throttel,clutch an exhaust are the main things really
gandy
Postby Luke » Fri Feb 18, 2011 10:20 pm
gandy wrote:hi just reading this now has anyone on here done it yet because i have just started doing my 51 plate 90/330 rwd now i have got the di engine in just need to sort out the throttel,clutch an exhaust are the main things really
how do you mean throttle :?:
wont the standard exhaust fit :?:
and what gear box are you fitting :?:
have you got any pics of it :?: :D
Postby gandy » Fri Feb 18, 2011 10:30 pm
i have got the 2.5 di out of a hi cube i have fitted the engine an gear box so need a cabe throttel now the exhaust manifold is on theother side i have took pics i will try an put them up when im done fitting it.
gandy
Postby Luke » Fri Feb 18, 2011 10:41 pm
can you just use a mk5 cable and weld the end of the mk5 pedal onto the mk6 pedal :?:
Postby Luke » Fri Feb 18, 2011 10:49 pm
how did you do the mounts :?: can you post some pics of them :D
Postby gandy » Fri Feb 18, 2011 10:53 pm
ye il take some pics tomorrow cut the one off the van an welded it up again
gandy
Postby StuartB58 » Tue Feb 22, 2011 5:23 pm
2.5DI in a Mk6 for sale on ebay so it has been done. Looks as if it could be tidyed up a bit better and thr speedo needs sorting.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 3D1&_rdc=1
MK6 Twin wheel 2.4 in white
Ford where rust is NOT an option.
StuartB58
Postby pat stevens » Wed Feb 23, 2011 10:45 am
ok so theres living proof that it can be done .certainly makes one bomb proof mk6 and if that goes as well as he says just think how it would go in a swb van certainly saves scrapping a good van just for the need of an engine im surprised theres not a lot more around the best bit buy a scrap mk5 theres plenty take out what you need then scrap it for nearly as much as youve paid for it very cheap conversion
pat stevens
Postby gandy » Sat Mar 12, 2011 1:11 pm
just to let you know done my van now its back on the road no problems with it just a little noisyer. Now bought another mk6 transit minibus with no engine or gearbox an i have got a 2.5 di turbo to put into that now.
gandy
Postby Luke » Sat Mar 12, 2011 4:46 pm
nice one 8) post us up some pics then :mrgreen: :mrgreen:
Postby gandy » Sat Mar 12, 2011 8:30 pm
gandy
Postby Luke » Sat Mar 12, 2011 11:04 pm
thanks 8)
certanly an interesting project............. i might do one one day :D
tight fit :o but goes in :lol: i see you've had to cut the crossmember :D
Postby pat stevens » Sun Mar 13, 2011 12:08 pm
think i might have a go at this when the mk1s done i need a new disco van
pat stevens
Postby PHILTHEWHITEVANMAN » Sun Apr 03, 2011 6:38 pm
nice work how did the propshaft fit to the mk5 gearbox just bolt up or not
PHILTHEWHITEVANMAN
