wheels for my cossie project....advice needed...
Re: wheels for my cossie project....advice needed...
Postby Gavin » Sun Apr 10, 2011 8:42 pm
its not the risk of them going down luke, its the risk of them popping off the rim :!: under hard cornering. a tubeless tyre wont leave the rim even when its shredded, so long as the bead wire stays intact and it dosent disintigrate - i had a blow out on the front at 70mph a few weeks back, its torn bead to bead, but didnt leave the rim so i still had enough control to cross three lanes and bring it to a stop, i still need a bead breaker to remove it, i cant get it off with tyre levers, tried that. but an under pressure tubeless tyre on a tubed rim would deflate and leave the rim suddenly if pushed :shock:
Gavin
Postby Luke » Sun Apr 10, 2011 8:52 pm
i was meaning his mod to the valve holes :D his havent come off and we fitted the tyres - tbh the rim didnt look any different to tubeless ones - mabe they aren't tubed ones :?
what size are the holes for the valves to go through on yours :?:
Postby Luke » Sun Apr 10, 2011 9:39 pm
you can sort of see here :?
Postby BROWNYS V6 » Mon Apr 11, 2011 8:14 pm
weighed my 6" weller today,just the rim is 9kg :wink:
BROWNYS V6
Postby Gavin » Mon Apr 11, 2011 9:46 pm
ooh bugger :shock: cheers for the info paul. gonna look into the standard defender ones see if they are lighter
Gavin
Postby turbokid » Sun Apr 17, 2011 7:52 pm
hi i have just had some 14" banded steels done for my mk5 they weigh 11.3 kgs just to let you know :wink:
ps your ideas for your van sound cool :D
turbokid
Postby AlanN » Sun Apr 17, 2011 9:39 pm
turbokid wrote:hi i have just had some 14" banded steels done for my mk5 they weigh 11.3 kgs just to let you know :wink:
Who did your bands and how much, Im on a waiting list, but I want them done for the summer...
Postby BROWNYS V6 » Sun Apr 17, 2011 10:24 pm
jesus christ military transit wheels :shock: gav u might aswell use the landy ones :?
how long u gotta wait al :?:
BROWNYS V6
Postby AlanN » Sun Apr 17, 2011 10:58 pm
Ive only been waiting since early Feb, but it took a few months just get on the list. I have could have gone elsewhere, but his work is second to none... BUT if the need arises
Postby Gavin » Sun Apr 17, 2011 11:59 pm
right im deffo selling these, ive found out that the standard defender steeles that look identical apart from the width being 5.5" not 6.5" are available in tubeless, and the backset of the wheel is the same as the ones ive got, so it will just be a case of getting the fronts banded as well as the rears. not sure on the weight but they are thinner steel so will be lighter...
Gavin
Postby MrMPuk » Mon Apr 18, 2011 7:17 pm
Could have saved some time if you'd listened. :lol: :lol:
Postby captain hook » Mon Apr 18, 2011 9:03 pm
How much for the L/R wheels?
Discovery Steels are 6.5in and Tubeless
I've got 10 here......
captain hook
Postby Luke » Mon Apr 18, 2011 9:54 pm
captain hook wrote:discovery Steels are 6.5in and Tubeless
can you weigh one :?: :idea:
Postby Gavin » Mon Apr 18, 2011 10:37 pm
i gave £100 for them so i'd be looking to get that back. not a lot as these retail for over £200 each :shock:
disco ones wont do as im after something looking near to the original transit shape, so only series or defender ones will do.
like i said earlier i always knew these might not be suitable and i'd be selling them on, but it was worth a punt as its proved a few things about it will work, and was actually the cheapest & easiest route to understanding the things i needed to establish....
Gavin
Postby captain hook » Mon Apr 18, 2011 11:40 pm
The wheels you have work fine tubeless..
I've had them 6 years on a Landrover.
They can be bought for £40 each, with good tyres
from Vass....An Ex Mil dealer in Bedfordshire.
Series and Defender Wheels are also "Tube-Type"
They can also run Tubeless.
The only Landrover rim that is made in "Tubeless" or "Tube-Type" is
the Wolf wheel and......You won't believe the weight of them :shock:
captain hook
