Cosworth boa manaul box
Re: Cosworth boa manaul box
Postby rob hall » Sat May 28, 2011 10:38 am
[quote][/quote]Image
the welsh A-team!
rob hall
Postby rob hall » Sat May 28, 2011 10:41 am
the welsh A-team!
rob hall
Postby Luke » Sat May 28, 2011 11:04 am
nice work 8)
Postby rob hall » Sat May 28, 2011 11:14 am
the welsh A-team!
rob hall
Postby MinorMatt » Sat May 28, 2011 5:01 pm
I think I am going to have to do the same with my clutch Rob...
Matt
Postby rob hall » Sat May 28, 2011 5:56 pm
Its a peice of cake matt, provide you got a spare lever!
the welsh A-team!
rob hall
Postby rob hall » Sun May 29, 2011 4:24 pm
Doing the down pipe/exhaust system tomoz and hopefully hopefully fitting the engine :D
the welsh A-team!
rob hall
Postby MinorMatt » Sun May 29, 2011 4:33 pm
Well I am going to have to drop the box... its just about my least favourite job - especially as I cant drive it on to ramps at the moment :?
Postby rob hall » Tue May 31, 2011 10:16 am
Engine is in! Pics will follow 2nite! Next on my list fab the front mounts
the welsh A-team!
rob hall
Postby Gavin » Tue May 31, 2011 11:52 am
nice work, going a lot quicker than mine :oops: are you using the ccosworth manifolds?
the genuine svo flywheel is deeper than the pinto one by about 30mm, so the stock clutch arm works, you can just about see it in this pic
Gavin
Postby rob hall » Tue May 31, 2011 5:41 pm
Problem! The starter isnt strong enough to turn the engine,ive had it tested and its ok, but it just isnt strong enough,has anyone else had this problem?
the welsh A-team!
rob hall
Postby rob hall » Tue May 31, 2011 6:25 pm
the welsh A-team!
rob hall
Postby rob hall » Tue May 31, 2011 6:28 pm
the welsh A-team!
rob hall
Postby rob hall » Tue May 31, 2011 6:30 pm
the welsh A-team!
rob hall
Postby Gavin » Tue May 31, 2011 7:36 pm
those manifold spacers are genius, obvious solution once you see them but no-one's ever thought of it before :!:
Gavin
