you will have the same braking area but you will get more force due to the increased radiustransitgeoff wrote:well if your gonna use the smaller pads what was the point of fitting the larger discs?? you will still have the same braking areajust fit the proper 190 pads
but thats not why im doing it, i wont be fitting transit discs, the only sizes i can get to suit my requirements are 270mm but the disk depth isnt as much as the transit............. but i may get away with it if i can fit the smaller pads to the larger calipers
so do they fit
