Luke's 24v cosworth into mk1/2 thread!!!
Postby Luke » Thu May 31, 2007 10:48 pm
same box as you mate :D ive a spare if that goes bang and by then i'll mabe have a few more - i'm hoping mt75 will be ok just getting a gooden :lol:
i'll get some pics :D promise :oops:
Postby custom » Thu May 31, 2007 10:52 pm
might look into rebuilding mine before i change it not sure yet either that or ill stick a cosworth clutch on it and hope for the best lol..
only other problem i have with the mt75 box is the ratios u might as well not have first gear and it isnt very good for 70 plus mph as its reving quite high
custom
Postby 24vMk2 » Thu May 31, 2007 11:03 pm
custom wrote:might look into rebuilding mine before i change it not sure yet either that or ill stick a cosworth clutch on it and hope for the best lol..
A couple of the 24v boys are using Transit TD clutches. I believe that supercharged Mk2 Escort on Ford Power is using a TD clutch. Thats got slightly more power than us 'normal' 24v peeps
BTW My Sierra 24v has killed an Escort Cossie clutch, and its only got an up-rated chip in her :(
24vMk2
Postby Luke » Fri Jun 01, 2007 3:26 pm
:( just looking at the amby tank - found its got a rust hole near the outlet :( worse tho :!: thought i'd try to start it with the new battery ive aquired good news started :) bad news - i'd knocked it it in gear and its spun half a prop up and ripped the centre bearing out of the chassis :x batterys ok tho :lol:
Postby rover » Fri Jun 01, 2007 4:14 pm
Luke wrote::( just looking at the amby tank - found its got a rust hole near the outlet :( worse tho :!: thought i'd try to start it with the new battery ive aquired good news started :) bad news - i'd knocked it it in gear and its spun half a prop up and ripped the centre bearing out of the chassis :x batterys ok tho :lol:
Oops! :shock:
Would the Granada tank not fit at all?
Rover.
rover
Postby Luke » Fri Jun 01, 2007 6:26 pm
rover wrote:Would the Granada tank not fit at all?
not really - its a bit too tall :(
for the prop - i'm thinking of using the lwb amby one - shorten both ends - i might even do it properly as its got the replaceable circlip joints in it :D
its also got some sort of rubber cusioning in it :)
for the tank - im thinking of making a swirl pot out of a metal fuel can fitting it under the van right next to the origanal tank :? :idea:
apart from that got 1 brake caliper fitted and started pipeing it up :D
Postby Luke » Wed Jun 06, 2007 12:38 pm
Just dropped the amby prop off for shortening and balancing :D i'm thinking of having an ally tank made - taken a few measurments and i think its the way to go 70litre and will fit in the same position as the origanal :D i'm just hoping i can get it made in time :)
but it's all coming together 8)
Postby KiloKilo » Wed Jun 06, 2007 12:51 pm
I think this thread is in desperit need of a photo of the beauty. :wink:
KiloKilo
Postby custom » Wed Jun 06, 2007 1:07 pm
(I think this thread is in desperit need of a photo of the beauty. )
ill second and third that we need pics
custom
Postby Luke » Sat Jun 09, 2007 7:06 pm
Props on all done 8) so once my fuel tanks in i can drive it :lol:
also fitted all the brakes - just need to fill and bleed em :)
JOBS LEFT
Battery - mount under seat and run wires!
fuel tank - fit
wire up cooling fan (allready fitted just need wiring)
make up exhausts - just 2 temporary systems to get it running and MOT'd
Postby Guy88 » Sat Jun 09, 2007 7:08 pm
Luke wrote:Props on all done 8) so once my fuel tanks in i can drive it :lol:
JOBS LEFT
fuel tank - fit
Nice one mate. hope it goes better than mine.
Have you loctited your flywheel on :lol: :lol:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby KiloKilo » Sat Jun 09, 2007 7:10 pm
JOBS LEFT
PHOTOSHOOT :wink:
fuel tank - fit
[/quote]
KiloKilo
Postby Luke » Sun Jun 10, 2007 1:32 pm
yes photos i know :roll: but ive forgot my camera again :oops: - i promise i will get some tho - but not much has visually changed only the engine - but at the moment its not the neatest conversion :(
just got the petrol tank off and bled the brakes :)
Postby Luke » Mon Jun 11, 2007 10:34 pm
today ive done a drawing of the petrol tank - im gonna get a quote for having it made tomorrow :)
the tank will house the origanal granada sender and pump, if anyone else is putting an injection (doesnt have to be a 24v) engine into a mk1 or mk2 then email me for a copy of the drawing if you want :D
Postby madmark » Mon Jun 11, 2007 11:43 pm
8) 8) comeing on then mate! :wink:
