No Pictures - available correct size pcd Transit alloys
Re: Pictures of all available correct size pcd Transit alloy
Postby wojciech » Tue May 05, 2015 10:37 am
New geniune Ford alloys 16" for Custom and Mk8 - from viewtopic.php?f=65&t=158140
wojciech
Re:
Postby slick91 » Thu Jun 18, 2015 2:14 pm
rover wrote:Ronal R44, 6.5x16
Rover.
Quite like these are there no prices and or special deals through the forum?
slick91
Re: Re:
Postby wojciech » Mon Jun 22, 2015 12:51 pm
Rover.
Some news about Ronal R44: for models Mk6/Mk7 Ronal R44 had flat socket for flat nuts with "swimming" washer.
Now Ronal R44 has conical socket - as genuine fords steel wheels and alloys for Custom and Mk8. But still it is possible use new R44 for Mk6/Mk7, because on market are available nice and cheap conical nuts M14x2mm.
wojciech
Postby wojciech » Sun Jun 28, 2015 3:43 pm
More pictures:
wojciech wrote:Model: Z1108, size 6,5 x 15", ET 50 mm, 5 x 160 mm, CB 65,1 mm, color: silver.
http://felgi1.com/?utm_source=sender&utm_medium=email&utm_campaign=Lenkijos%2Brinkai%2B2015%2F03%2F17
Producer: :?: , model: 1108, size 6,5Jx15, PCD 5x160mm - conical, ET 50mm, CB 65,1mm, finishing: silver.
wojciech
Postby wojciech » Mon Jul 20, 2015 11:31 am
German Transit Custom Business Edition is equipped with 18" alloys with tyres 235/50R18. Alloys are available only with this model...
http://www.westfalia-mobil.net/modelle/ ... er_web.pdf
wojciech
Postby bj928 » Fri Aug 07, 2015 4:21 am
all the wheels below are 5x160 PCD thanks to amoerica now getting the new transit
20" and 22"
bj928
Postby wojciech » Wed Aug 19, 2015 11:55 am
Wolfrace for Transit - size 8x20", ET 60 mm, load rated to 1350kg :!: :?: , price 890 GBP
They are looking as STORM 36 18"...
In this so big wheels so small disc brakes are looking little bit... miserable. :cry:
wojciech
Postby VooDoo » Wed Aug 26, 2015 11:25 am
VooDoo
Postby wojciech » Wed Sep 09, 2015 9:59 am
They are Indonesian alloys for Mitsubishi MS-396... :?
http://www.velgmobil.com/productdetail. ... d_name=296
wojciech
Postby wojciech » Tue Oct 06, 2015 10:30 am
OZ Racing alloys - limited version for Custom M-Sport, 18".
wojciech
Postby scottyderg » Fri Oct 30, 2015 9:02 am
Will a set of ford c max 16 alloy fit a mk 7 transit? Currently has the 15 standard steels on! Cheers
scottyderg
Postby Dodge20 » Fri Oct 30, 2015 12:05 pm
Even if they did fit they wouldn't be legal because of the load rating.
Some people are like slinkies.... not good for much but bring a smile to your face when you push them downstairs.
2009 280 85hp
2015 290 Custom DCIV twin side doors 155hp(tragically killed)
Dodge20
Location: Go to the end of the world and turn left. (South Cumbria)
Postby wojciech » Fri Oct 30, 2015 7:37 pm
scottyderg wrote:Will a set of ford c max 16 alloy fit a mk 7 transit? Currently has the 15 standard steels on! Cheers
No. Only Transit alloys fit Transits... :cry:
wojciech
Postby wojciech » Mon Mar 14, 2016 12:46 pm
Propably Forgiato Inc./USA, size 7,5Jx18, PCD 5x160
Price:
US $1,044.99
http://www.ebay.com/itm/NEW-2015-2016-F ... fresh=true
They are known as 20-inch version from Transit Skyliner built by Galpin Auto Sports in Van Nuys, California viewtopic.php?f=64&t=149977
wojciech
Postby wojciech » Fri Apr 08, 2016 11:50 am
RacingLine, model 343S, size 6,5Jx16, PCD 5x160mm, offset (ET) 50mm, load capacity 1025kg
wojciech
