yes you can get them for mk3 that should just fit strait inredeemer wrote:So there is no LSD from later trannyies that would fit in the mk2 housing?
ginsambo wrote:Luke, did you press fit your discs over new studs with a longer non-threaded section or just keep them in place with the wheel nuts / wheel?
no it's supposed to be hammered black but its more like smooth grey but it matches the van so it'll doginsambo wrote:Is that smoothrite metalic paint?
mabe - got to break a few MT75's 1st thoginsambo wrote:All you are missing is the T5 box now?
allready done it matecamper extraudinair wrote:Hi Luke
If your going to change the rear axle for a lsd.
same to youcamper extraudinair wrote:I must say i admire you for your dedication
determination & hard work you have put into
the convertion good luck in your future efforts.
