at the backslogger wrote:How is it mounted to the chassis , that has to be one of the best mods to do to a mk1 aside from putting in a di
one thing to think of is there's a bit less clearance with the ifs crossmember over the beamcarnut1100 wrote:Haha! Mine's a 4.1 litre crossflow six, and if that changes at all it will only be for the EFi version of said crossflow six...
24v wrote:I am in the middle of this conversion at the moment and see that the spindle to take the column is up against the filter which in turn is very close to the exhaust.Can I rotate the filter bracket to clear it?
Cheers
yes - filter is directly onto the block, i got rid of the whole arm thing, i can't rememebr what i did with the pipes - i think from memory they come from the heater so you can remove one pipe and fit the other direct24v wrote:I have the oil/water cooler still attached and a leg that goes down aboct 3 inchs and the filter attachs to this.You have all this removed and the filter direct to the block?If so did you just connect the water pipes together?
