VAG 1.9 TDi into a RWD transit
Re: VAG 1.9 TDi into a RWD transit
Postby martynx » Sat May 07, 2016 10:06 pm
Different issue then;) I'm sure you'll suss it out.
martynx
Postby Luke » Sat May 07, 2016 10:27 pm
hope so :|
it's pissed me off a bit i was there thinking just the propshaft and i can go for a drive 8) 8) 8) then pressed the clutch :evil: :evil: :evil:
now its all got to come back out :roll:
Postby Luke » Sun May 08, 2016 11:29 am
just dropped the box and i think i have the wrong clutch - bought it as a 2.0 but i think its a 2.5 :evil:
that would explain why i needed to get the adpaterplate machined down :idea:
any VW experts? i wouldnt mind knowing the answer to these q's
are 2.0 and 1.9 tdi cranks the same length?
is the flywheel bolt patten on the 2.5 and the 1.9/2.0 the same?
is the release cylinder the same on the 2.5 gearbox and the 2.0
not really sure how to progress this - i'll see it i can get it swapped for a 2.0 or see if i can fit the 2.5 release cylinder/bearing
Postby Luke » Sun May 08, 2016 11:37 am
not so sure now - looks like i have the correct clutch it's the same part no. as this one
http://www.ebay.co.uk/itm/VW-Crafter-Sp ... 1636911329
and thats listed as a 2.0 :?
Postby karl » Sun May 08, 2016 11:46 am
ive only ever done 1 vw 1.9 passat clutch and that was a few years ago
karl
Tranny Lover!!!
Postby Luke » Sun May 08, 2016 4:38 pm
well found out its the same part number for the 2.5 and 2.0 cylinder/release bearing - so that shouldn't be the issue :?
Postby Luke » Sun May 08, 2016 8:44 pm
just had the clutch off can't see anything wrong :? there's about 10 deg rotation in the duel mass flywheel but i think thats normal
havent took the flywheel off yet - still can't understand why i needed to mill the adapter plate down :? :? wondering if it's that flexing as i dont have the sump part to support it
Postby Luke » Mon May 09, 2016 7:57 pm
i am now thinking the gearbox i have been supplied might be a bad one :roll:
i thought i'd have a closer look at the release bearing - it feels good and smooth - the noise is really loud so i dont think its the problem
what makes me think the box is bad is the pinion nut is missing off the rear flange :? and there has been a few loose bolts on it as i was installing it
there was a drip of oil from the input shaft (the bellhousing was covered in oil when i split it)
when i removed the release bearing/cylinder and there is no seal behind it - i can't see where one would fit not sure if this is this normal but i can't see how it would seal otherwise :?
Postby bambi mk 1 » Mon May 09, 2016 8:53 pm
What box are you using Luke :?: Lts have the cyl on the outside.
bambi mk 1
Postby Luke » Mon May 09, 2016 9:20 pm
it's a 2012 6 speed crafter box from a 2.0 Tdi - it's the cable change one :D
Postby bambi mk 1 » Mon May 09, 2016 9:27 pm
I have a Lt engine and box on the ground that I can take a few measurements if you wish :)
bambi mk 1
Postby Guy88 » Mon May 09, 2016 9:28 pm
Luke wrote:it's a 2012 6 speed crafter box from a 2.0 Tdi - it's the cable change one :D
if there the same as sprinter ones the good ones are like chocolate :(
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Mon May 09, 2016 10:00 pm
not sure if they are the same internally but externally they look different :|
tbh if i got one that worked ok i can't see it having much of a hard life in this - never going to carry much weight of do that many miles
Postby Guy88 » Mon May 09, 2016 10:02 pm
if you need any info im working on a 2.5tdi 2010 crafter atm
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Mon May 09, 2016 10:09 pm
well this is my box (same type as this)
http://www.ebay.co.uk/itm/2012-VOLKSWAG ... SwPhdVUy1b
don't really know much about it - they are different to the crafter 2.5 box
