My Essex V6 Transplant
Re: My Essex V6 Transplant
Postby Leeday » Mon Sep 01, 2014 7:53 pm
Hi Madbri and whitemice,
Thanks for the replies,
Will check the prop tomorrow,
Its definitely road speed, not engine speed, faster you go, louder it gets, got to 50mph and then chickened out and stayed at 40mph.
1989 Mk3 swb, 3.0 V6 Essex, 5 Speed Manual: http://fordtransit.org/forum/viewtopic. ... 3&t=142054
2005 Mk6 2.0 Duratorq 100 T350 MWB Semi High
Leeday
Postby whitemice » Mon Sep 01, 2014 7:57 pm
prop angle alignment?
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby Leeday » Mon Sep 01, 2014 8:02 pm
whitemice wrote:prop angle alignment?
Since fitting the V6 and MT75 and using the prop-shaft from Matt which mounts to the original factory mounting brackets on centre bearing I have done approx. 350 miles with no noise or issues, drove to a job and all was fine, then got in van to drive home and it started to make this noise from immediately pulling away :?:
Will check the alignment of the engine/gearbox and prop to axle :D
Leeday
Postby robbie.cee » Mon Sep 01, 2014 8:56 pm
If you drive at 40 then stick van In neutral whilst moving (coasting ) does it still make noise... will help eliminate if its input or output related...
Gutted we missed ya at mania, do love the rumble of an essex at wide open throttle under load !!!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby robbie.cee » Mon Sep 01, 2014 8:57 pm
Gotta say my essex/mt75 took some proper abuse (Burnouts doughnut s drag racing )and never gave any grief, sticking starter different story(carry a rubber mallet in van)
Had
MAKE IT FIT
robbie.cee
Postby whitemice » Mon Sep 01, 2014 9:44 pm
Sound and vibration level increasing with roadspeed to my mind indicates propshaft issue, Madbri may be onto it with the bearing/rubber.
U/J
whitemice
Postby limitedblack » Mon Sep 01, 2014 10:34 pm
Could just be some debris stuck against the prop. Would explain the flapper noise.
Happy Easter
limitedblack
Postby whitemice » Mon Sep 01, 2014 11:06 pm
limitedblack wrote:Could just be some debris stuck against the prop. Would explain the flapper noise.
yeah, that's been posted about before, bit of immigrant or summat.
whitemice
Postby limitedblack » Mon Sep 01, 2014 11:11 pm
My handbrake cable rubs on the prop, surprising how much noise that can make, and of course when you check underneath you have the handbrake on, so it's not touching then.
Happy Easter
limitedblack
Postby whitemice » Mon Sep 01, 2014 11:58 pm
ziptie?
whitemice
Postby Leeday » Tue Sep 02, 2014 12:44 am
Cheers guys for the input :D
Will be under the van tomorrow and checking things, will post my findings, if it is something simple to fix I will be extremely happy, as the thought of removing the gearbox again, single handled is a daunting thought :cry:
Leeday
Postby Leeday » Wed Sep 03, 2014 7:05 pm
Hi all,
Sorry for delay, got under van today and put a straight edge along the prop-shaft and it is out of true. Running a edge along full length of prop keeping it true from back axle to centre bearing it is about almost 20mm out at gearbox flange.. The engine and gearbox are sat correctly in their mounts, the back axle is sat correctly positioned on its springs, seems like I need to move the centre bearing mount over slightly, but the adjustment slots are front to rear and not side to side, so unsure what to do.
As the Essex V6 is from a Mk2 ambulance is it possible the Mk2 transit centre mount was positioned in a slightly different place to my Mk3.
After driving and listening "harder" it does seem that the noise is coming from the centre bearing, under the van I can move the prop in its bearing but not excessively.
Cheers.
Leeday
Postby madbri » Wed Sep 03, 2014 8:55 pm
lee can u undo and remove the prop easy? if so id do that and run ure van up without prop through ure gears and listen. if no noise then u can asume its prop / diff.
madbri
Postby Leeday » Wed Sep 03, 2014 11:29 pm
madbri wrote:lee can u undo and remove the prop easy? if so id do that and run ure van up without prop through ure gears and listen. if no noise then u can asume its prop / diff.
:D Sounds like a great idea Bri.... wish sometimes I could solve my problems with the same logic :?
Need to use the van tomorrow for work, so fingers crossed and 30mph all the way there and all the way back and hopefully nothing breaks or explodes :lol:
Will then whip prop off, if it is the prop, then I still have the Mk5 prop that I made the "fabricated mount" for (earlier on this thread) as I know that prop was running true.
Cheers Bri, No doubt will be picking your brains again later :D
Leeday
Postby madbri » Thu Sep 04, 2014 5:23 pm
called thinking outside the box... easy ways 1st... but it still might be a gear selectoer in the box wich only sometime will show when under stress :roll: or im talking bollox :lol: :lol:
madbri
