No Pictures - available correct size pcd Transit alloys
Re: Pictures of all available correct size pcd Transit alloy
Postby wojciech » Mon May 06, 2019 6:52 pm
RRW/JWL, model RR5-V, size 7.5J x 17", ET 30/50 mm, backspacing: 5.43" (+30 offset) / 6.22" (+50 offset), PCD 5 x 160 mm, load rating: 1.655kg/3650 lbs (heavy duty load rating)
wojciech
Postby wojciech » Sun May 19, 2019 7:56 pm
OEM alloys for Transit Custom Sport, size 7,5Jx18", ET 56 mm, PCD 5 x 160 mm, mounted with tires 235/50R18. With this alloys van has lowered series from 310 to 290 (lower load).
wojciech
Postby wojciech » Sun May 19, 2019 9:27 pm
MAK, model Load 5, size 6,5J x 15", ET 58 mm or 6,5 x 16", ET 60 mm or 7,0 x 17", ET 55 mm, PCD 5 x 160 mm, finishing: Silver lub Ice Black, axle load index of 2.700kg
Marka MAK, model Load 5, rozmiar 6,5J x 15", ET 58 mm lub 6,5 x 16", ET 60 mm lub 7,0 x 17", ET 55 mm, PCD 5 x 160 mm, wykończenie: Silver lub Ice Black
wojciech
Postby wojciech » Mon May 20, 2019 8:17 am
MAK, model Stone 5,
size:
6,5 x 15" ET58 mm
6,5 x 16 ET 60 mm
7,0 x 17 ET 60 mm
7,5 x 17 ET 52 mm
7,5 x 18 ET 50 mm
PCD 5 x 160 mm, load 1.150 kg, finishing: Silver, Gloss Black, Black Mirror
wojciech
Postby wojciech » Mon May 20, 2019 4:27 pm
Ford OEM alloys for Transit Custom Sport/Tourneo, size 7.0 x 17", ET 55 mm, PCD 5 x 160 mm.
wojciech
Postby wojciech » Mon May 20, 2019 4:55 pm
X
wojciech
Postby wojciech » Mon May 20, 2019 5:15 pm
Unknown producer, "Made in TR" (Turkey?), size 7.0J x 17", ET 55 mm, PCD 5 x 160 mm
On wheel is located certification mark of JWL Standard (Japan Light Alloy Wheel standard).
wojciech
Postby FritzZeus » Mon Jul 15, 2019 11:53 pm
Hi
Anyone know of any specific Wolfrace wheels that will fit please
FritzZeus
Postby bj928 » Tue Jul 16, 2019 4:14 am
is there any 10J wheels or even 9J, from what i can tell, 8J is the widest available from anyone for a transit
bj928
Postby wojciech » Mon Jul 22, 2019 5:10 pm
bj928 wrote:is there any 10J wheels or even 9J, from what i can tell, 8J is the widest available from anyone for a transit
I think - you can think only about steel banded wheels as a viable option.
wojciech
Postby bj928 » Mon Jul 22, 2019 6:11 pm
thats what i'm thinking, a good set of banded, but i think then i can only go 16", or maybe 17", working on an idea with another transit nut, to change to f150 ford 6x135 stud pattern all round without adapters, use a narrowed f150 axle on the rear, and maybe change just the hubs on the front, opens up 100's of choices in wheels
bj928
Postby wojciech » Tue Jul 23, 2019 1:38 pm
bj928 wrote:thats what i'm thinking, a good set of banded, but i think then i can only go 16", or maybe 17", working on an idea with another transit nut, to change to f150 ford 6x135 stud pattern all round without adapters, use a narrowed f150 axle on the rear, and maybe change just the hubs on the front, opens up 100's of choices in wheels
It is big project. Godspeed...
wojciech
Postby wojciech » Sat Aug 03, 2019 7:10 pm
ALUWERKS model SPYDER, size 8J x 18" ET 45 mm, PCD 5 x 160 mm, CB 65,1 mm, load 1.250 kg (2.755 lbs), finishing: GLOSSY, genuine nr st18SPYDERHPS
wojciech
Postby wojciech » Tue Aug 27, 2019 5:25 pm
RONAL, model R64, size 7,0J x 17", ET 53 mm, CB 65,1 mm, PCD 5 x 160 mm, finishing: R64S - silver, R64JBM/FC - Jetblack-Matt/Frontcopierd.
wojciech
Postby wojciech » Fri Dec 20, 2019 6:07 pm
PDW Australia, model 50343, size 8Jx18", PCD 5 x 160 mm, CB 65,1 mm, load 1.015 kg, finishing: black gloss + polishing
Certificate ISO, VIA, JWL
wojciech
