VAG 1.9 TDi into a RWD transit
Re: VAG 1.9 TDi into a RWD transit
Postby Luke » Wed Jul 06, 2016 8:39 pm
nice 8) looks a bit more space in there :D mines the same it's the back axle diff - i would say even a 3.5:1 would be ok in it :D
see he's got the standard air box on - i need that too :mrgreen: and if he's got an inter cooler then its down near the front right wheel :D
Postby Luke » Wed Jul 06, 2016 8:44 pm
today i fitted a new 4.56:1 diff - same ratio but this one is much better nick - it's cut down on the whining and over run vibrations 8)
also found i didn't have a good body earth and i've replaced that found a few more loose bolts and stuff - generally making it better each time i find one :lol:
main jobs to do once i get back from north weald is fill all the bulkhead and floor holes and get some sound deadening down then fit a standard air box as the intake whistle is really annoying :lol:
Postby Luke » Mon Jul 11, 2016 11:32 pm
managed a 'proper' road test this weekend - towed petes jag van down to north weald for a run down the strip :D
all the way down the A1 and back i managed to keep it in 6th gear even up the hills - really impressed with it 8)
picture of us ready to set off :D
Postby andz327 » Wed Jul 13, 2016 11:08 am
Nice, well done, hows it on fuel or can't you tell yet
andz327
Postby Luke » Wed Jul 13, 2016 6:53 pm
andz327 wrote:Nice, well done, hows it on fuel or can't you tell yet
difficult to tell as i was towing but it's done over a tank to north weald and back - once im running about properly i'll do an accurate test and see exactly :D
Postby a7djc » Fri Sep 09, 2016 8:35 am
hi just come across your thread
did you use adaptor plate between engine and box
looking to putt tdi lump and audi 4x4 box in to a mk6 jumbo as specialise in vw
and had enough of the problems in 2.4 engine in my race van and race vw so got plenty of engines and spares
also 4x4 van would mean i can go anywhere as using as a camper too
2004 Mk6 Transit Jumbo 90ps
Faults faults and more faults, will be my race van eventually for European Rallycross
a7djc
Postby a7djc » Fri Sep 09, 2016 9:45 am
also did your van pull the other transit fine
even tho i'm planning 200hp and 350lbft, i'm still concern its gonna pull 5.8ton train
a7djc
Postby Luke » Fri Sep 09, 2016 1:06 pm
i used the VW adapterplate from the crafter
it pulled the van fine - since then ive pulled a series 3 109 landrover & trailer 350miles and it did that no problems - i would think 5.8 ton with 200bhp would be no problem :D
Postby a7djc » Fri Sep 09, 2016 3:23 pm
brilliant, its what the standard 90ps 2.4 was rated for
can you remember what the minimum wires you needed to run was
and if you fancy cruise control i think you can add it with 3 or 4 wires and an audi switch, will have a look as easy to retrofit on vws
a7djc
Postby Luke » Fri Sep 09, 2016 5:23 pm
quite a few wires (too many to count) but not as many as the toyota one ive done :lol:
if you look back in the thread there is a pic of a cardboard box with all the wires in - thats all you need to run it
the problem with cruise control is i think i need the speed sensor working - i dont have that yet
Postby vekcina » Sun Oct 22, 2023 7:22 pm
Greetings Luke!
Thank you for all the info on this build, it was a pleasure to read!
I am making an m-tdi myself and searching for the right transmission. Can you elaborate on the crafter adapter plate? Did you get it premade from some retailer or is it a common part for the different versions of the crafter?
I can't get any decent hits on google from where I'm searchin'.
vekcina
Postby Luke » Sun Oct 22, 2023 11:12 pm
vekcina wrote:Greetings Luke!
no it's a VW part, i've just searched back i thought i had posted the part number
i'm sure ive got a drawing somewhere with the part number on it i'll see if i can find it :D
Postby vekcina » Mon Oct 23, 2023 9:20 am
OHH yiss great news! From the writing it sounded like a VW part, but it just won't pop up in the search results.. Much appreciated! If you can't find it, I'll try asking around the VW mechanic circles, but here nobody is to keen on indulging guys doing conversions :(
vekcina
Postby Krisdupreysgarage » Mon Oct 23, 2023 9:53 am
vekcina wrote:OHH yiss great news! From the writing it sounded like a VW part, but it just won't pop up in the search results.. Much appreciated! If you can't find it, I'll try asking around the VW mechanic circles, but here nobody is to keen on indulging guys doing conversions :(
Hi! Luke very kindly gave me the part number a while ago, here it is :)
03L103647E 01S 3310
(VW) DE GDD
I bought one off Estonian eBay, not opened it yet. Will be starting my build around Christmas so will update then lol
Krisdupreysgarage
Postby vekcina » Mon Oct 23, 2023 11:40 am
Hi! I appreciate it very much! Managed to find some options for ordering already, you've helped me a great deal.
Cheers!
vekcina
