stephenferguson wrote:hello Hillman
Just ordered my dash off ebay, i need the gear cables tho, and what is that part i need for the gearbox end?
Also does the newer headlight switch work?
any pointers appreciated
stephenferguson wrote:Hi,
Yeah i'll put all the pics to my front end conversion sticky.
Did you use the mk6 heater controls? Does the mk7 ducting attach to the mk6 heater system?
What are the mk7 Fixing points like are they the same as the mk6?
Mine are the digital clocks, its on an 06.
Sorry to bombard you with questions!!!
Regards
Regards
hillman wrote:i'm now thinking of doing the front.
hillman
Vandalism wrote:hillman wrote:i'm now thinking of doing the front.
hillman
you know it makes sence![]()
transitsonly wrote:was the hole easy to do for the gear cables? how did you mark the hole? also how is the gear changing? is there more room or are they tight? i am good on the electrical side so i hope to work out the wiring on the hazzards. if i do i will let you know. also i will be working on the steering wheel. i will post some photos if i can do it. i will be starting mine in a couple weeks cause i have to get all the bits together first. if someone can let me know about the hole for the cables that will be good. regards Tony
Punto443 wrote:What did you do regarding the fog lights? Only I just noticed after ripping out and changing my dash that there is no warning light on the mk7 light switch,
