So first up remove the flywheel:
Bolt the plate onto the gearbox:
This modification to the gearbox to allow the starter motor to fit had already been done for me by Tim, so slotted starter motor in to check and it fits perfectly, next to look at exhaust clearance, so temporary aligned gearbox to back of engine:
Put exhaust pipes into place to check for clearance:
Due to different manifolds to the Granada manifolds Tim used to make the adapter plate, I have had to grind away a different part of the gearbox and some of the adapter plate:
However one problem I have is that 3 holes in the adapter plate that holds the plate to the engine using 1 countersunk bolt and 2 normal bolts are unuseable as my engine does not have the threaded holes in the block to use them, where as the donor engine Tim used to make the plate obviously did have the holes:
Plate still has 8 other bolts and 2 dowels holding it in place so I don`t think it will separate or twist with the Essex V6 torque and power doing 0 - 60mph in 3 seconds
So bolted the adapter plate onto the back of the engine:
Also M8 x 170mm bolt arrived today (to hold alternator to its mount) but its a part threaded bolt that is to long making the thread to short, so decided to make my own, got my M8 threaded rod, welded a nut to the top of it, ground it to a nice shape, cut it to the correct length, the 2 bushes I made to move the alternator forward on its mounts are M10, so with the M8 bolt through it allows the alternator to twist, so drilled the 2 (thick) bushes out and inserted 2 lengths of M8 steel tube, this then gives me a good thick bush that will fit tighton the M8 bolt and prevent the alternator twisting:
