jag v12 conversion is started
Re: jag v12 conversion is started
Postby skiddy75 » Wed May 21, 2008 6:56 pm
on 1 website i looked at they do a adapter plate and flywheel for manual box but what box i dont know
skiddy75
Postby MrMPuk » Wed May 21, 2008 6:56 pm
skiddy75 wrote:on 1 website i looked at they do a adapter plate and flywheel for manual box but what box i dont know
Or which website.
Postby skiddy75 » Wed May 21, 2008 6:58 pm
dont know had to clear all cookies etc cos computer running slow
skiddy75
Postby MrMPuk » Wed May 21, 2008 6:59 pm
skiddy75 wrote:dont know had to clear all cookies etc cos computer running slow
Not alot of help then!
Postby skiddy75 » Wed May 21, 2008 7:05 pm
sorry i will look again later if i find it i will post it
skiddy75
Postby Luke » Wed May 21, 2008 7:54 pm
dont you want to keep the auto :?:
Postby mantav8 » Wed May 21, 2008 8:19 pm
I would!-IIRC it's a Borg warner Standard,good boxes!
AFYI, you can get adapter plates for all manner of boxes for the V12! :wink:
mantav8
Cosworth Powered
Cosworth Powered
Postby skiddy75 » Wed May 21, 2008 9:15 pm
i have to keep the auto due to foot well space the engine alone is wide and long
skiddy75
Postby Sundowner » Fri May 23, 2008 9:31 am
mantav8 wrote:I would!-IIRC it's a Borg warner Standard,good boxes!
Thats no borg warner behind that V12 thats a GM turbo 400 an extremely strong auto box
Sundowner
Postby skiddy75 » Fri May 23, 2008 8:01 pm
ok lads i will let u know what box it is :lol:
skiddy75
Postby lostpaul67 » Fri May 23, 2008 8:12 pm
T260/130ps Glx
My Mk7 Ford Transit161k miles
lostpaul67
GLX Posse - Founder member
Postby mantav8 » Fri May 23, 2008 8:46 pm
There standard then?
mantav8
Cosworth Powered
Cosworth Powered
Postby Sundowner » Mon May 26, 2008 11:09 am
Yep only behind some V12's
Sundowner
Postby bazw » Wed May 28, 2008 5:21 pm
was going to do this to frankensprinter ( had a xjs donor ) , by hell its hard work getting them out lol
i would have had to make 2 small boxes to weld into the foot wells ( 9"high x6" wide x3" deep ) to clear the inlets and back of heads
all well till i found a crack where block had frozen over winter :( so ended up on here with a di in it :shock:
it might be worth just bundling all the harness up in a box and running the injection system instead of adding carbs as i think the ignition is linked to the same brain iirc
i think the toymotor supra twin turbo box is a common swop for manual but you would need arms like an orangutan to change gear its so long , other common option is a T5 box
there are the odd bits and bobs in my garage if you need owt electronics boxes and things
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby clampitt bus man » Tue Jun 10, 2008 7:21 pm
this project is cool as fook
clampitt bus man
