Terry wrote:HI
The Range Rover conversions were PROBABLY done (originally)to make them useable as fire tenders.
So try a fire engine maker/builder...Chubb used to do builds but I don't know if they still do.
Go to your local small airfield they probably have a 6 wheel RR, the idea obviously was they can carry the extra weight (of water) & go cross country to get to the burning whatever.
H.T.H.
Terry
Guy88 wrote:How about having a peer under the back of a twin axle renault master type thing
93fxdl wrote:......Ok, who wants to give me a hand then
well if your in the south of glasgow ill fire up the 9 inch (grinder that is)
as for the twin axle conversion a couple of suggestions create a subframe from box to mount all suspension to (easier than lying under a van trying to figure out where everything should mount and when you want to weld underneath just turn it over) and unless you are planning using the van to carry serious loads softer springs will be needed so you can use shorter springs to get the axles closer together or maybe coilovers or air springs
ttfn glenn
93fxdl wrote:Guy88 wrote:How about having a peer under the back of a twin axle renault master type thing
not sure (probably wrong) but i believe the master is front wheel drive
ttfn glenn
mk5 100lwb semi high roof, soon to be turbo!!
