24v cosworth transplant
Postby crazyscoot » Sun Apr 02, 2006 7:40 pm
im watching this thread with anticipation!! keep it coming coz im well interested :D
Negative reality inversion
crazyscoot
Postby OxtonyxO » Sat Apr 08, 2006 8:36 pm
anyone going to undertake this transplant beware look at this :!:
click here for pic!
:D :D :D :D
OxtonyxO
Postby bortaf » Sat Apr 08, 2006 11:44 pm
I think you'll get more power if you remove the cat :lol: :lol:
:oops: sorry couldn't resist that one :D
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby OxtonyxO » Sun Apr 09, 2006 8:03 am
:D :D :D :lol:
OxtonyxO
Postby schmacster » Sun Apr 09, 2006 8:58 am
OxtonyxO, dont forget to label every wire and if poss make a detailed plan of the wiring, Sh~# load of work i know but it will be very useful for people on the forum......namely me :D
I know you probably will anyway mate, but dont forget to SOLDER and heat shrink all your connections. I know a guy near me that took a smart car roadster engine and loom and put it in a ....wait for it......reliant kitten! The wiring on the roadster is complex to say the least With traction control/stability control/abs/air bags/leccy seats you get the idea :shock: He stripped down the loom and made all his new connections with connector blocks and tape :shock: I did try to tell him but he wouldn't listen and after finally wrapping up all the loom and putting it in place, he now has loads of electrical probs :shock: . The first time you do the loom, make it the last time and do it right :wink:
schmacster
Postby OxtonyxO » Sun Apr 09, 2006 3:23 pm
thats not my loom mine is still in the granny waiting for an engine host at the moment
but thanks for the advice
:!: :!: he did it with connector blocks (good job then) :!: :!:
OxtonyxO
Postby Valsheda » Sun Apr 09, 2006 4:29 pm
bortaf wrote:I think you'll get more power if you remove the cat :lol: :lol:
:lol: :lol: :lol: :lol: brilliant :lol:
Valsheda
Top Tourneo Owner
Postby madvanman » Wed Apr 12, 2006 2:32 am
before pulling the loom apart like that check for a 12 pin plug in the dash loom (above right hand side of glovebox) as the 2.8i granadas engine loom is a separate loom despite being taped together with the dash loom, if ford did the same in the 24v granny you will only have to deal with 12 wires and just transplant the engine + ecu loom intact
madvanman
Customised!!
Postby Scooby » Thu Apr 13, 2006 3:15 pm
I am looking at doing this conversion, where can i get this adapter plate from and are they fitted standard on some transits ?
Scooby
Postby MrMPuk » Thu Apr 13, 2006 3:18 pm
If you have a read through the post all of you questions have been answered already!
Postby OxtonyxO » Sun Apr 30, 2006 7:31 pm
right found a redrilled pinto plate
the plate has had a piece welded to the top and then redrilled to suit the v6
will post a pic later
OxtonyxO
Postby OxtonyxO » Mon May 01, 2006 6:30 pm
here is the picture of the plate plus the custom made manifolds to get the exhaust past the mt75 bell housing
notice the welded on piece at the top as this was a pinto plate!!
OxtonyxO
Postby Scooby » Mon May 01, 2006 10:08 pm
Cheers matey, thats very very helpfull. :lol:
I should be doing my conversion soon.
Scooby
Postby OxtonyxO » Thu Jun 01, 2006 8:59 pm
after having done a bit of research about the gear box
i need to know if anyone can confirm that the svo mt75 v6 boxes are the same as standard ones?
i have been told that the standard box will work if you use the spacer from between the crank and the torque converter, how ever the person that did this did not fit a spigot bearing! but it worked and was reliable
on looking on other web sites the non transit mt75 had to have longer input shafts fitted and a clutch mod
hope you can understand all this!
and if anyone can confirm any of this that would be great
OxtonyxO
Postby 24vMk2 » Wed Jun 07, 2006 11:38 pm
Where did you get your front pipes / manifold from?
24vMk2
