landrover wellers re-drill help
Re: landrover wellers re-drill help
Postby AndyG » Wed Feb 10, 2010 1:20 am
Good job the price was right :D
Those tyres (235/85/16) won't fit in the standard MK5 arches :(
Postby spike72 » Wed Feb 10, 2010 3:32 am
i am going to put 195-65-16 tyres on but was thinking of putting 205-65-16 on the rear with flared wheel arches on the rear but dont think the sliding door will open properly ????
spike
spike72
Postby Luke » Wed Feb 10, 2010 10:36 am
spike72 wrote:what diameater hole and how deep do you go champher
13mm dia hole and the chamfer is about 1-2mm deep depending on the thickness of the wheel as a rule go 2/3rds in - what you dont want is to go too far in and open up the 13mm hole - if you want an exact measuremnt let me know the thickness of the bit the holes will be going through :D
spike72 wrote:so as i take it 160 pcd 60 degree champher just need the above confirmed
yup :D
Postby Luke » Wed Feb 10, 2010 10:54 am
madbri wrote:sorry to hi jack :wink: luke do u thunk its poss to weld up holes and redrill 4 6 stud? or cut the centre out and make a new boss for 6 stud? just dont fancy changing for 5 stud axle ect :wink: ure the 1 id trust for advice :wink:
i've thought about these before :D as mentioned the offset can be a problem but if i was doing it i think i'd cut out a piece of steel and weld it to the back of the weller then drill through that :idea: and also welded the old 5 holes up :) but probly a lot more work than converting to 5 stud :lol:
minormatts been looking at it too :D
Postby spike72 » Wed Feb 10, 2010 1:12 pm
once again cheers luke much appriciated
managed to talk local engineer in to doing it after showing him this thread and showing pics of mattblackminibus with the wellers on lol
spike72
Postby Luke » Wed Feb 10, 2010 1:14 pm
spike72 wrote:once again cheers luke much appriciated
nice one mate :D glad to help 8) 8)
dont forget them pics :wink: 8)
Postby madbri » Wed Feb 10, 2010 1:16 pm
thanks luke :wink: problem with 5 stud the insurance want an engineers report done! the van ant worth that sort of money spending on her il get a nice set of trims :(
madbri
Postby MinorMatt » Wed Feb 10, 2010 4:18 pm
Im going to fit a 5 stud axle redrilled to 6 stud jap PCD
Postby madbri » Wed Feb 10, 2010 4:36 pm
MinorMatt wrote:Im going to fit a 5 stud axle redrilled to 6 stud jap PCD
cant u make an adaptor plate? y do u have to fit a 5 stud set up
madbri
Postby MinorMatt » Wed Feb 10, 2010 6:11 pm
because I dont want my wheels sticking several inches out from under the arches...
The 6 stud axle is only about 2" narrower than the van (not scientifically or accurately measured!) and by the time you put an adaptor plate on its going to be significantly worse. The other thing I have considered is a twin wheel axle, but its putting a load of load on the bearings so I discounted it although it may be possible on the back - front would be the same problem :s
Postby madbri » Wed Feb 10, 2010 6:23 pm
oh sh*t i c now :twisted: no wonder there ant sexy wheels 4 a six stud :evil:
madbri
Postby 1949bug » Thu Feb 25, 2010 9:45 am
This thread is seriously lacking pictures :(
1949bug
Postby flashbaztard » Fri Mar 19, 2010 7:26 pm
i am thinking of doing the same
but to make it easier i was thinking of cutting the centres out of tranny wheels [5 or 6 stud] then welding them to the outside of wellar rim and just drilling the holes out
that way the wellars would be sandwiched between the hub and wheel centre's
and how about jacking up the back wheel of your tranny [with tranny wheels on]
put it in first, ticking over then bodge a jig with a cutting blade as a homespun lathe to cut the centres out
see tranny owners can think!
if you get injured , i deny posting this, [the cat was using my pc,summat to do with the mouse!]
flashbaztard
Postby darkbluevanman » Thu May 06, 2010 8:41 pm
Let's have a piccy of some landy wheels fitted to a tranny... what happens with the old holes? in a cosmetic sense?
darkbluevanman
Postby Luke » Thu May 06, 2010 10:53 pm
darkbluevanman wrote:Let's have a piccy of some landy wheels fitted to a tranny... what happens with the old holes? in a cosmetic sense?
the set i did for martin he welded over the old holes but most just leave them on as they dont look out of place with the nuts :D
