Mk5 cosworth boa
Re: Mk5 cosworth boa
Postby rob hall » Fri Feb 04, 2011 10:14 pm
Sorry will the xr4 cluch handle the power/torque of the cosworth engine
the welsh A-team!
rob hall
Postby Luke » Fri Feb 04, 2011 10:29 pm
what size diameter is it :?: i would imagine so :D
mine used the standard transit v6 clutch and didnt have a problem- i cant rememebr the size but im pritty sure i documented it in my progress report :D
Postby rob hall » Fri Feb 04, 2011 10:33 pm
Thank u.
:D
the welsh A-team!
rob hall
Postby rob hall » Mon Feb 07, 2011 8:40 pm
Hi which starter motor will I need, I have a pinto
adaptor plate ,and xr4x4 flywheel ,mt75 van gearbox
the welsh A-team!
rob hall
Postby Luke » Mon Feb 07, 2011 8:57 pm
rob hall wrote:Hi which starter motor will I need, I have a pinto
have a read of guy88 and oxtonyxo's progress reports they did it that way - i thought they used the pinto flywheel redrilled - and i think the xr4i flywheel is used if you use the car mt75 :)
Postby rob hall » Mon Feb 07, 2011 10:52 pm
Oh sh*t , so the xr4x4i flywheel wont do with mt75 van box then,??
the welsh A-team!
rob hall
Postby rob hall » Tue Feb 08, 2011 8:45 am
Whay thinkness is the pinto adaptor plate? Cos mine is about 2mm thick have I got the right one?
the welsh A-team!
rob hall
Postby Luke » Tue Feb 08, 2011 6:21 pm
rob hall wrote:Whay thinkness is the pinto adaptor plate? Cos mine is about 2mm thick have I got the right one?
pritty sure its thicker than that :? sounds like you might have the plate that goes between engine and box that keeps the crap out of the bellhousing :)
do you need 3 seats up front :?:
Postby rob hall » Tue Feb 08, 2011 7:03 pm
Yep deffo need 3 seats,i bought the bellhousing adaptor from burton power. what thickness should it be?
the welsh A-team!
rob hall
Postby Luke » Tue Feb 08, 2011 7:25 pm
rob hall wrote:Yep deffo need 3 seats,i bought the bellhousing adaptor from burton power. what thickness should it be?
post a pic of it - i dont have one to hand but the svo one is about 15/20mm thick :)
Postby Gavin » Tue Feb 08, 2011 7:38 pm
dirt plate
http://www.burtonpower.com/catalogue-20 ... e-114.html
adapter plate
http://www.burtonpower.com/sc1281.html
same thing, sandwich plate. its not what you need, get your money back. the correct definition of an adapter plate is a plate that allows an engine of one bolt pattern to be mounted to a box with a different pattern.
sandwich plates often get called adapter plates for some reason :?
Gavin
Postby Luke » Tue Feb 08, 2011 7:58 pm
rob read through these threads :D
:arrow: viewtopic.php?f=27&t=5594
:arrow: viewtopic.php?f=27&t=7596
they use the pinto adapter plate with a V6 cossy :D
Postby rob hall » Wed Feb 09, 2011 7:54 pm
Thank u luke,they help alot,just need 2 find a adaptor plate now!
the welsh A-team!
rob hall
Postby rob hall » Wed Feb 23, 2011 2:04 pm
Ive just bought a pinto adaptor plate and flywheel and starter for £40! But it cost me £27 in diesel to collect it
the welsh A-team!
rob hall
