Cosworth boa manaul box
Re: Cosworth boa manaul box
Postby Luke » Tue May 31, 2011 7:50 pm
yeah top idea 8) but by the time you've made some your half way to making a pair of these :mrgreen:
then you can add a couple of turbos :twisted: :lol:
Postby rob hall » Tue May 31, 2011 9:14 pm
Thanks m8, but still can work out how to sort the? starter problem
the welsh A-team!
rob hall
Postby Luke » Tue May 31, 2011 9:26 pm
whats the problem - starter not meshing with the flywheel :?:
Postby Luke » Tue May 31, 2011 9:30 pm
just read - not strong enough :? odd one :?
i know that my svo one was the same as the granada but the pinion had 1 tooth different - mabe it was 1 less to gear it up a bit :idea: i think it was 9 tooth :? how many is yours :?:
Postby rob hall » Wed Jun 01, 2011 7:43 pm
10 teeth on the starter, its a pinto starter, I got it when I bought the adaptor,flywheel,they all came off a pinto transit. Im told that the v6 starter wont do as it has 11 teeth.
the welsh A-team!
rob hall
Postby Luke » Wed Jun 01, 2011 10:43 pm
mine must have 10 and the granada 11 then :?
have you seen the engine running :?: and does it turn over by hand easly :?:
Postby rob hall » Wed Jun 01, 2011 11:46 pm
yep,engine turns over by hand and was running fine before I pulled it out!
the welsh A-team!
rob hall
Postby Luke » Wed Jun 01, 2011 11:49 pm
i wonder if the starter isnt meshing with the flywheel correctly - too far in or something :?
i'd have thought thats more chance of being the problem :!: :D
Postby Gavin » Wed Jun 01, 2011 11:52 pm
try it with the plugs out?
is the clutch dragging?
Gavin
Postby rob hall » Sat Jun 04, 2011 4:02 pm
Progress
Engine mounts done
Downpipes removed -due to catching on front cross member
Oil in gearbox
Gear lever fitted
the welsh A-team!
rob hall
Postby rob hall » Thu Jun 09, 2011 9:08 pm
got the starter back today, so will fit it tomoz! Also got my new fuel line,8mm insulated copper pipe,going to run it inside the cab and though the bulk head,
the welsh A-team!
rob hall
Postby rob hall » Thu Jun 09, 2011 9:13 pm
Also trail fitted rad and fan, but fan was touching the engine pulleys so going to remount the fan to the front of the rad! ,
the welsh A-team!
rob hall
Postby Luke » Thu Jun 09, 2011 9:49 pm
making good progress 8)
personally i wouldnt run fuel lines inside the cab - last thing you want in an accident is a split line pumping fuel inside the cab :shock:
Postby rob hall » Thu Jun 09, 2011 10:21 pm
Which way would you run the fuel lines ? The original lines run to close to the exhaust for my liking!
the welsh A-team!
rob hall
Postby Luke » Thu Jun 09, 2011 10:30 pm
i see your point i ran mine tied up to the floor and over the exhaust - mine had enough air space but you could get a heat insulation to put over them if its close - i'd still rather go that way than inside the cab - not sure but it might be an MOT fail :? it's not allowed in racing :)
