My Essex V6 Transplant
Re: My Essex V6 Transplant
Postby Leeday » Sun Nov 02, 2014 9:01 pm
andypdq wrote:I am not familiar with these axles, but it looks very similar to the design of a Land Rover axle. If that's the case, then you just pull the halfshafts, undo the ring of bolts and the complete crownwheel, pinion, diff and carrier bearings drop out in one piece, they are all fastened to the "nose" casting, easy. This means you could easily fit a complete second hand assembly without having to dismantle the diff itself. No where near as heavy as a complete axle, so cheap carriage. Perhaps someone could confirm if i'm right. :D
Many thanks, I was hoping so and thanks for confirming.
Have had a day of excessive rain, so nothing done to van today :(
First hint of sunshine and I will be attacking it :D
1989 Mk3 swb, 3.0 V6 Essex, 5 Speed Manual: http://fordtransit.org/forum/viewtopic. ... 3&t=142054
2005 Mk6 2.0 Duratorq 100 T350 MWB Semi High
Leeday
Postby madbri » Sun Nov 02, 2014 10:10 pm
First hint of sunshine and I will be attacking it with petrol and a match :D
:shock: :shock: :oops:
madbri
Postby Luke » Sun Nov 02, 2014 10:26 pm
you are indeed correct :D
Postby Leeday » Wed Nov 05, 2014 10:03 pm
Today worked on the axle:
Sequence order:
Jacked up van, axle stands under each end of axle,
handbrake off,
spun passenger wheel by hand: spins freely and continues to spin until it stops,
spun drivers side wheel: very notchy and stops as soon as you let go,
Removed drivers side wheel, brake drum and half shaft,
Drivers side hub spins freely with no notchyness, hold opposite wheel studs and can find no play up/down left/right etc in wheel bearing.
Splined end of half shaft shows no signs of damage or wear.
As advised by MinorMatt "put the half shaft back in - without the drum and try spinning the hub. If its notchy its 100% definately the diff"
Done this and yes all notchy and noisy so its been confirmed its definitely the Diff that has failed.
Leeday
Postby Leeday » Thu Nov 06, 2014 12:15 am
Anybody got a mk2 / mk3 diff with ratio 3.89 or 4.11 for sale that will fit my van?
Leeday
Postby Leeday » Sat Nov 08, 2014 12:19 pm
A Diff, A Diff, My Kingdom For a Diff.
Leeday
Postby madbri » Sun Nov 16, 2014 4:46 pm
madbri
Postby madbri » Sun Nov 16, 2014 4:47 pm
madbri
Postby Leeday » Sun Nov 16, 2014 8:12 pm
Hi Bri,
Thanks for looking out :D
Been told by Minor Matt I need a pre 91 diff, as my half-shafts wont fit the mk4 and mk5 diff.
Also my axle is the narrow axle same as mk2, if I fit the later wider axle then my 10" wheels wont fit :(
So needs to be a mk2 or mk3 diff unit.
Leeday
Postby Leeday » Fri Nov 21, 2014 2:33 pm
Hi all,
Does anybody have or know of a diff for sale as I desperately need one urgent as the one I was waiting for has fell through.
Needs to be pre 91 mk3 4.56 or even better 4.11.
Thanks.
Leeday
Postby BROWNYS V6 » Fri Nov 21, 2014 11:22 pm
lee, can you not get yours repaired with new bearings ?
BROWNYS V6
Postby Leeday » Sat Nov 22, 2014 12:26 am
BROWNYS V6 wrote:lee, can you not get yours repaired with new bearings ?
Hiya.
Not took my diff out yet as thought I had a replacement in the pipeline and so straight swap.
Will get my diff out this week and see what's failed and if I can repair it or get it repaired.
Will venture into it and update as I progress.
Leeday
Postby robbie.cee » Sat Nov 22, 2014 10:47 pm
Look at burtonpower ilford website they sell pinions crown wheels etc
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby madbri » Sun Nov 23, 2014 7:44 pm
madbri
Postby madbri » Tue Dec 23, 2014 5:28 pm
any news lee?
madbri
