My Essex V6 Transplant
Re: My Essex V6 Transplant
Postby Leeday » Wed Dec 24, 2014 12:44 am
madbri wrote:any news lee?
Hi Bri,
Sorry for delay.
Van is still sat in the garden, untouched and unmoved, been using the car for work.
Still deciding what to do with the van, struggling with finding a diff, (had 3 lined up and all fell through) may have to travel to mainland for new or repair etc and its all more cost, haven`t took diff out yet in case I decide to sell it and so its still moveable (onto a trailer),
so don`t know what I`m doing at the minute.
1989 Mk3 swb, 3.0 V6 Essex, 5 Speed Manual: http://fordtransit.org/forum/viewtopic. ... 3&t=142054
2005 Mk6 2.0 Duratorq 100 T350 MWB Semi High
Leeday
Postby madbri » Wed Dec 24, 2014 8:09 am
:shock: :shock: sell it :shock: :shock:
ffs dont do that m8
madbri
Postby MinorMatt » Fri Jan 02, 2015 9:01 pm
I will have another rummage around tomorrow and see what I can find.
I've said I have a later diff you can have - but you would have to swap the centers over (assuming yours is ok) which is a bit fiddly but not hard
Postby BROWNYS V6 » Sat Jan 03, 2015 12:01 pm
selling up is a bit extreme lee, got a noisey mk3 diff here, maybe get new bearings fitted and just swop it over :idea:
BROWNYS V6
Postby MinorMatt » Sat Jan 03, 2015 5:31 pm
Nope can't find it
Postby Leeday » Wed Jan 07, 2015 4:45 pm
Hi All,
Hmmmm ... well after a great christmas / new year away in the motorhome in Polperro Cornwall, come back refreshed and decided to attack the van :D
van ready for diff removal:
Finally removed diff, can`t see alot wrong, but not sure what I am looking for:
Does look like there is some where on the cogs bottom edge:
Any advice on what I should be looking for?
Cheers.
Leeday
Postby BROWNYS V6 » Wed Jan 07, 2015 7:11 pm
it does look like there is some wear/damage on the crownwheel, looks like its got some rust on it too, can you see if the pinion has any damage, if you grab the diff flange and turn it, how much play before it starts turning the crownwheel ?
BROWNYS V6
Postby Leeday » Wed Jan 07, 2015 7:56 pm
BROWNYS V6 wrote:it does look like there is some wear/damage on the crownwheel, looks like its got some rust on it too, can you see if the pinion has any damage, if you grab the diff flange and turn it, how much play before it starts turning the crownwheel ?
Hiya,
Thanks for reply......
Think I have found the problem, following your advice I turned the diff flange and crownwheel moves instantly, turned diff upside down and looked in whilst turning the pinion flange and found the problem.... pinion has lost / sheared some of its cog bit where it engages with crownwheel:
Leeday
Postby blue estate » Wed Jan 07, 2015 7:58 pm
Hiya,
OUCH! :shock:
blue estate
Postby BROWNYS V6 » Wed Jan 07, 2015 9:21 pm
jesus lee, the technical term for that is its fooked :shock: least you found the problem :lol:
all I can say is my diff here is in better condition than that one :wink:
BROWNYS V6
Postby Leeday » Wed Jan 07, 2015 9:41 pm
BROWNYS V6 wrote:jesus lee, the technical term for that is its fooked :shock: least you found the problem :lol:
:lol: was driving with it like this, no more than 30mph at the end, but the noise became so loud, it had to be parked up :lol:
Leeday
Postby madbri » Wed Jan 07, 2015 10:31 pm
yep thats the problem :( mine had no teeth leth when i finnished it was just spinning :lol:
madbri
Postby BROWNYS V6 » Wed Jan 07, 2015 10:41 pm
tis the reason why my v6 transit has an atlas axle up its arse :mrgreen:
well that and the better selection of ratios :wink:
BROWNYS V6
Postby Leeday » Wed Jan 07, 2015 11:24 pm
BROWNYS V6 wrote:tis the reason why my v6 transit has an atlas axle up its arse :mrgreen:
What are my best options then?
Replace crown-wheel and pinion for new and find someone to install the crown-wheel and pinion into the diff housing for me,
Keep looking for a 2nd hand diff,
Or install an Atlas Axle?
Was the Atlas Axle from a capri and if so what mods are required, is the axle wider than the mk2 mk3 narrower transit axle (if yes my wheels won`t fit), etc, etc..
Cheers :D
Leeday
Postby BROWNYS V6 » Thu Jan 08, 2015 1:40 pm
hi lee its a proper transit axle, bolt it straight on, rare as rocking horse poop but i know a man who has one :wink:
BROWNYS V6
