My Essex V6 Transplant
Re: My Essex V6 Transplant
Postby Leeday » Sat Jan 16, 2016 4:17 pm
:D Inlet Manifold now removed :D
1989 Mk3 swb, 3.0 V6 Essex, 5 Speed Manual: http://fordtransit.org/forum/viewtopic. ... 3&t=142054
2005 Mk6 2.0 Duratorq 100 T350 MWB Semi High
Leeday
Postby walt1984 » Sat Jan 16, 2016 5:40 pm
Sounds like your sorted but just in case there is also Essex engines in darwin, Lancashire.
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Postby whitemice » Sat Jan 16, 2016 9:01 pm
Leeday wrote::D Inlet Manifold now removed :D
ha, was gonna say i have a spare inlet manifold if you knackered yours.
I need an o/s cast exhaust manifold as i want to make up a new exhaust system this year, i have asked on here previously but no joy so i am considering welding one up with a kit off these folk
http://www.ebay.co.uk/itm/FORD-3L-ESSEX ... 4e7a:g:HLc
as i have a new set of downpipes off a scimitar and a new stainless set of pipes and boxes off a landy. my o/s cast exhaust manifold has a missing lug that broke off and i had to bodge a fix that i really need to sort out this year.
Funny enough my fuel pump frapped out a few month back and i managed to get a brand new one off a capri specialists,
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby Leeday » Sun Jan 17, 2016 12:25 am
Thanks for the offer whitemice :D
I still need to get the exhaust system sorted out on mine as all i done was welded the downpipes (where they go from 2 to 1) to my original pinto exhaust system and really would like twin pipes right through, just got to find someone on the island who can fabricate a twin exhaust system in stainless :D .
Leeday
Postby robbie.cee » Tue Jan 19, 2016 5:02 pm
Buy some stainless mig wire n do it itself mate
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby Leeday » Thu Jan 21, 2016 11:43 am
Hi Robbie,
Have thought of that, but would like the tubes to be curved to shape over the back axle rather than lots of welding.
If I can`t find anyone to do it, might contemplate attempting it myself :D
Leeday
Postby Leeday » Thu Jan 21, 2016 11:45 am
Another quick question:
The inlet manifold is bolted on using 8 bolts, the 4 middle bolts have standard bolt heads but the 4 outer bolts have allen key heads :?: is this correct or has someone mis-matched the bolts.....
Leeday
Postby Leeday » Sun Jan 24, 2016 5:19 pm
Hi,
In my head set I have 5 paper gaskets to bolt the carb to the inlet manifold, all having various differences in the centre cut outs, in the manual it says these must be replaced in the same order as the old ones that came off :roll: I did not make a note of this, does anyone know the correct order of fitment for these 5 gaskets?
Cheers.
Leeday
Postby Leeday » Sun Jan 24, 2016 7:18 pm
First head off:
and the naughty blown gasket:
2nd head off:
Slowly re-assembling:
These are the 5 gaskets I now have to fit, but don`t know what order they go in.... does anyone know: also have a "diffuser" that goes in between some of these gaskets (its a thick plastic base with 2 metal v prongs to spread the fuel):
Leeday
Postby DrDeAtH » Sun Jan 24, 2016 10:18 pm
Should be carb. Paper gasket. Spacer. Thick gasket. Manifold.
Just use the one that has the best fit in regards to the openings.
DrDeAtH
Postby Leeday » Sun Jan 24, 2016 11:21 pm
DrDeAtH wrote:Should be carb. Paper gasket. Spacer. Thick gasket. Manifold.
Many thanks DrDeAtH :D
Leeday
Postby robbie.cee » Mon Jan 25, 2016 3:44 pm
How bloody heavy are the heads.... Gotta be nearly 20kg A piece
Had
MAKE IT FIT
robbie.cee
Postby Leeday » Mon Jan 25, 2016 5:10 pm
Certainly makes your eyes bulge when you are leaning over the front of the van trying to lift them out and then gently replace them without dropping them onto the new head-gasket :lol:
Leeday
Postby whitemice » Mon Jan 25, 2016 8:27 pm
8)
whitemice
Postby derv23 » Mon Jan 25, 2016 8:31 pm
Looking good Leeday. Nice looking motor too.
MK5 Tourneo.
derv23
