Transit Custom mods and 'upgrades'.
Re: Custom mods and 'upgrades'.
Postby limitedblack » Sun Mar 23, 2014 9:50 pm
Is the answer a?
Happy Easter
limitedblack
Postby Mike » Sat May 10, 2014 1:02 pm
Fitted the TomTom at last
Which involves taking the van apart! Stoney, thanks for the heads up on how to remove the A pillar trim.
Mike
Wind up merchant!
Postby SteveO » Sat May 10, 2014 8:04 pm
Hey Mike,. Which mount did you use to fix it up there? Was it the standard sucker on that comes with the TomTom or something else? Also got any final pics of the power connections connected up? Thanks.
SteveO
Postby Mike » Sat May 10, 2014 8:17 pm
I used one of these on the black mesh area of the screen http://www.amazon.co.uk/gp/product/B001 ... UTF8&psc=1 and a USB extension cable to get the power lead into the dash-top power socket. Sorry no other pics but you just take out the bits that you can see in the pic, then remove the two screws at the front of the dash-top compartment, then you can feed the cable down.
Mike
Wind up merchant!
Postby SteveO » Sat May 10, 2014 8:45 pm
Ah brilliant thanks Mike much appreciated.
SteveO
Postby ezywheels » Sat May 24, 2014 10:56 pm
Great post! Any chance of a spreadsheet listing specific light and your recommended upgrade! [WINKING FACE]
ezywheels
Postby ezywheels » Tue Jun 03, 2014 9:37 pm
Hi Mike. Which LED replacement did you use for the number plate lights? Cheers.
ezywheels
Postby Mike » Thu Jun 05, 2014 9:10 pm
ezywheels wrote:Hi Mike. Which LED replacement did you use for the number plate lights? Cheers.
http://www.powerbulbs.com/product/w5w-l ... white-twin
Mike
Wind up merchant!
Postby ezywheels » Fri Jun 13, 2014 11:09 am
Thanks for all the help Mike.
For those interested, www.powerbulbs.com are doing a Father's Day Promotion at the present. 20% off. Code FATHER20. Use until the 16th June.
Cheers.
ezywheels
Postby CamsTrans » Sat Jun 21, 2014 10:45 pm
bigjohnthomas wrote::? but whats that in inches then what does it all mean :?
i shall rephrase my question ..
from a human perspective dose it "feel" any smaller in the back ?
I have 2 bits of timber in the back of my vans attached to the wheel arch boxes to separate it out a bit for when the bikes go in the back. Don't have to empty the lot then. I took it out the MK7 and I had to cut about 3 inches off them to fit in the Custom. So unless you've got something huge that only just fitted in the MK7 you'd probably be ok. Plenty of room to wash dog's ring pieces :lol:
58 Transit Connect swb LR 75 (Gone)
08 Mk7 Transit Limited swb LR 140 (Gone)
14 Transit Custom Limited swb 125 8)
CamsTrans
Postby Mike » Wed Aug 27, 2014 7:30 pm
Yellow drl problem solved!
Mike
Wind up merchant!
Postby limitedblack » Sat Aug 30, 2014 2:57 pm
Looks good mike, is this the normal drl position?
Happy Easter
limitedblack
Postby Mike » Sat Aug 30, 2014 4:22 pm
Nope, the normal drl is part of the main beam light. This drl is in the fog light position, it operates as a drl/fog/cornering light.
Mike
Wind up merchant!
Postby oldyellar » Sun Aug 31, 2014 12:44 am
Mike wrote:Nope, the normal drl is part of the main beam light. This drl is in the fog light position, it operates as a drl/fog/cornering light.
Led com?
oldyellar
Postby Mike » Tue Sep 02, 2014 2:13 pm
Led com?
Nope, Osram http://www.amazon.co.uk/LEDriving-assis ... riving+fog
Mike
Wind up merchant!
