Pictures of all available correct size pcd Transit alloys
Re: Pictures of all available correct size pcd Transit alloy
Postby wojciech » Mon Feb 03, 2020 5:14 pm
DEZENT Wheels - Member of the ALCAR, model Van and Van Dark, size 6.5Jx16", PCD 5 x 160 mm, ET 60 mm, load 1.350 kg
wojciech
Postby wojciech » Mon Feb 03, 2020 5:18 pm
CMS ALLOY WHEELS model Carna (CMS 268 ), size 6,0Jx14", PCD 5 x 160 mm, ET 20 mm, ain't central bore - on Timken rear axle (Transit Mk3,4 and 5) wheels are centered only by nuts
wojciech
Postby wojciech » Mon Feb 03, 2020 5:19 pm
CMS ALLOY WHEELS, model CV1(CMS 426), size 6,5x16", PCD 5x160mm, offset 60mm, finishing: High Gloss Silver.
wojciech
Postby wojciech » Mon Feb 03, 2020 5:21 pm
Borbet CW model CG, size 6,5Jx16", ET 60 mm, PCD 5 x 160 mm, , load 1.350 kg 1350 kg, finishing: Cristal Silver.
wojciech
Postby wojciech » Mon Feb 03, 2020 5:24 pm
Borbet CW model CH, size 6,5Jx16" , ET 60 mm and 7,5Jx17", ET 47 mm, PCD 5 x 160 mm, load 1350 kg, finishing: Silver or Mistral Anthracite Polished
wojciech
Postby wojciech » Mon Feb 03, 2020 5:26 pm
Borbet CW model CWC, size 6,5Jx16", ET 60 mm, PCD 5 x 160 mm, ,flat nuts, load 1350 kg
wojciech
Postby wojciech » Mon Feb 03, 2020 5:28 pm
Riviera model Trekker, size 8.0Jx18", PCD 5 x 160 mm, ET 45 mm, load 1.050 kg.
wojciech
Postby wojciech » Mon Feb 03, 2020 5:33 pm
RIVIERA, model VIGOR , size 7,5Jx18", PCD 5 x 160 mm, ET 45 mm, or size 8,0Jx20", PCD 5 x 160 mm, ET 50 mm. Both versions have very low load - only 850 kg - I think - acceptable only for lightest versions of Transit Custom.
wojciech
Postby wojciech » Mon Feb 03, 2020 5:36 pm
Riviera model RTS, size 8.0Jx20", PCD 5 x 160 mm, ET 50 mm - "available in a range of finishes" (?)
wojciech
Postby wojciech » Mon Feb 03, 2020 5:39 pm
Riviera model RTT, size 8.0Jx20", PCD 5 x 160 mm, ET 50 mm, load 900 kg
wojciech
Postby wojciech » Mon Feb 03, 2020 5:54 pm
Alcoa Wheels/USA, alloys for dual wheel model
https://www.arconic.com/alcoawheels/cat ... hicles.pdf
For dual wheel van (6 x 180 mm, central bore 138.8mm - inside wheel on rear axle, between hub and alloy, must be steel.
wojciech
Postby wojciech » Mon Feb 03, 2020 5:55 pm
wojciech
Postby wojciech » Mon Feb 03, 2020 5:58 pm
ALCOA USA, model 26190x, size 6.5Jx16", PCD 5 x 160mm, bolt hole diameter 16,5mm, offset 60mm, high max load 1.360kg = 3.000 lbs
http://www.arconic.com/alcoawheels/cata ... hicles.pdf
wojciech
Postby wojciech » Mon Feb 03, 2020 6:59 pm
Autec, model Talos (T), rozmiar 6,5Jx16", PCD 5 x 160 mm, ET 56 mm
also known as MAK model HD2, size 6.5x16", PCD 5 x 160 mm, ET 60 mm
wojciech
Postby wojciech » Mon Feb 03, 2020 7:04 pm
TSR model Camion, size 6,5x16", PCD 5 x 160 mm, ET 60 mm
on smaller (second) picture wheel is with correct PCD 5x160 mm
wojciech
