roof mounted monitors
Re: roof mounted monitors
Postby executivetravel » Mon Nov 24, 2008 12:12 pm
im gonna do the unthinkable.....lol
im gonna cut a 2" square hole in the headlining, and hope i can access the roof panel above, if i can, then i can bond/glue a short bracket/post about 4" long (will measure thru the hole) which i can use to mount a new backing plate im ordering from an aluminium supplier
wish me luck.... :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops:
executivetravel
Postby executivetravel » Mon Nov 24, 2008 3:48 pm
I cut the square out to find the whole of the headlining is formed into ducting for the roof vents
in for a penny, in for a pound, i went thru that and found the roof panel
the "dropper" needs to be only 2.25" deep and 2" square so ill be down the builders merchants looking for any item to suit, ive ordered a pc of ally 5mm plate 14"x11" for the base plate
and ordered some sikaflex 255 adhesive
should i remove paint from the roof panel to key the glue to it?
executivetravel
Postby executivetravel » Tue Nov 25, 2008 2:21 pm
hole cut
ally plate on its way
two 90 degree brackets cut,drilled and bolted together, sikaflex on its way
how long does that stuff take to go off, i hope i havent gotta hold the bracket upto the glue for two days, my arms will ache
executivetravel
Postby custom » Tue Nov 25, 2008 5:13 pm
executivetravel wrote:hole cut
in this weather it will take about 24 hours to fully cure and set so you will need to get something to hold it up till its set but on the plus side it is awsome stuff ive used it loads of times and its incredably strong stuff
custom
Postby executivetravel » Tue Nov 25, 2008 5:39 pm
ive bought the "255" variant, no-one seemed to know which was best
update :- im considering 4 bolts thru the roof, dont trust glues....
executivetravel
Postby executivetravel » Thu Dec 04, 2008 6:40 pm
well the bonding glue went awol in the post, so i spent time hand crafting a bracket
the nylok nut is held by superglue, and i shall superglue a 3/8" drive 8mm socket on the nut so i can tighten it up as the bolt comes thru the roof.
i shall bond it to the roof too.
the 5mm ally plate is all drilled ready
got the 2 angles from the local builders merchants...if i had a garage or shed id be dangerous, im restricted to the dining room table!
executivetravel
Postby executivetravel » Tue Dec 09, 2008 2:53 pm
that sikaflix stuff is evil, like black coal tar, glad to dump what i didnt need!
executivetravel
Postby executivetravel » Thu Dec 11, 2008 1:48 pm
in and working and even a good view from the rear row of seats
executivetravel
Postby Luke » Thu Dec 11, 2008 6:23 pm
got there in the end :lol: nice job and it looks well 8)
Postby executivetravel » Fri Dec 12, 2008 9:07 am
now looking for a "full" media player (300 films+160gb of music £120)
the inverters in and waiting...
executivetravel
Postby bigmastif » Fri Dec 12, 2008 3:35 pm
nice job 8)
bigmastif
Postby executivetravel » Sun Dec 14, 2008 5:26 pm
found out the head unit plays CD-G discs, which means..
http://www.gaapweb.com/news/1251-Busine ... -taxi.html
executivetravel
Postby executivetravel » Wed Dec 17, 2008 9:32 am
ive got a whine on the radio
more so on a weak station and when the headlamps are on, so im assuming its from the alternator
anyone know anything about smoothing/chokes to fit and where/how?
executivetravel
Postby Guy88 » Wed Dec 17, 2008 10:27 am
have you got HID's
If so do you find it worse when there on :?:
Mines real bad and rises and falls with engine revvs, so if you find a cure let me know please 8)
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby executivetravel » Wed Dec 17, 2008 2:18 pm
hid?
tested the leccy
11.89v at standstill
14.68v running 1500 rpm
14.08v at 1500 rpm with main beams on
executivetravel
