custom wrote:Luke wrote:custom wrote:just been and measured mine looks like there 274mm wide and depth is about 56mm so not much difference
hmmmmnow does the 4mm matter
only 2mm either side
could the btm pivot be modded mabe
would be good to try some transit shoes inside a vw drum to see if they would bed in okcould do with a trip to the motorfactors
ive just checked my haynes manual it says for my axle the drums are 254.0mm so it wouldnt work would it?
you might find the transits in inches and the vw's metricGavin wrote:according to ebaymk4 tranist 5 stud is 254mm i.d x 90 high. drums are usually sized in inches just like wheels, so that is an 10" drum, and the 270mm vw one is probably 270 o.d. making it an 10" drum also. so they may well fit.
the killer will be the weather seal to the backplate though![]()
might be possible to fit t4 backplates and run complete t4 rear brakes, should be easy to re-drill (and if necessary space out) the backplates
i was thinking more of the link bars that go across - but like you say worth a lookGavin wrote:as for the backplates, if it isnt big enough just cut the middle out and weld a bit in, you only need the rim and the pivot and lug points. in any case its got to be worth a look.
Luke wrote:on your hubs if they are circular - unlike my mk1 ones why not drill and tap 5 new holes at 160 pcd and put some studs in - that way they wont go through because of the shank of the stud and wont come out because of the wheelperfectly safe
Gavin wrote:bet they are imperial, even on modern fords and japanses cars with metric bolts the brakes all have imperial threads in the fittings and imperial bore sizes in the cylinders. even the motorbikes do!.
Luke wrote:i'm also a bit unsure of the unsupported length between the half shaft face and the wheelyou could get the studs bending due to that section
how does it drivethey look to be a little off centre but mabe its the camera angle
it's a shame they wern't 140's you could have probly got that throughthe drum
i'd forgot you had done those drawingsHaxman wrote:I am assuming hub to be same as a mk2 though...
hmmmmHaxman wrote:Ah neat, would those hubs fit a mk 2 then or is there more to it then that?
Luke wrote:well i cant understand a word of itbut looking at the pics this imo is how adapters should be - having the centre boss to support the new wheel
if they do fit VW wheels then the boss will be 57mm and req an adapter ring if you were to fit mercedes wheels which have a 66mm centre bore
