cant wait to see how you get on with this it sounds good nice choice of color too
belly wrote:id stick with white and just make it mint135
then you can fit the 135 axle 3.63! i think it was available in drw as well ? i would have thought you can just chuck one wheel on as two wheels just mate up to each other anyway, just for mobility i wouldnt drive it like that
i think its only me and you that like 135's
you said the van was originally together and working? only reason i ask that is because where that weld mark or whatever it is? just behind it the grey oxide is where they sit on the skids in the plant and as they go through the paint shop that bit doesnt get painted! so once its been through the trim lines still on skids they tranfer to a cradle to go on the merry go round (engine assembly line) once the running gear is fitted they come down a bit lower other underside bits are fitted inc the spare wheel which is also where the guy on that station paints with a brush the oxide for the un painted parts! now on that station there was one guy but two shifts! one old dude who just dabbed it on not giving a monkeys and the other guy was a younger caring type of bloke who got told off frequently for slapping loads on
i didnt want them to rust
anyway know ive bored you on that the main reason i asked is because some of the first shells were used as mock ups to re fab the old skids to fit the new model that would explain the burn type looking thing! i did thing about a rogue robot but it wouldnt have been painted!
