thats strange
- it maybe that taking the plugs out just makes it easy enough to turn and isnt actually the problem
is the starter definatly in the right position
can you loosen the starter bolts and pack it out a bit with some shims then tighten back up and try it - or even bolt it up on 1 bot but move it out a bit to make sure its lined up right
