mk6 to mk7 dash
Re: mk6 to mk7 dash
Postby tony&kasia » Tue Dec 02, 2014 12:38 am
I'm taking out the mk7 dashboard tomorrow. Should be fun. My first time.
I have never liked a sardine can with a bonnet, How can you possibly own the road
tony&kasia
Re: mk6 to mk7 dash
Postby tony&kasia » Tue Dec 02, 2014 9:53 pm
Ok I removed the mk7 dash out the doner van today. Just a couple things will the mk7 heater work in the mk6? And also I noticed there are 3 clips holding the dash in up near the windscreen instead of bolts. Will that make a difference? I do have the clips. Will these clips fit the mk6.
tony&kasia
Re: mk6 to mk7 dash
Postby Punto443 » Tue Dec 02, 2014 11:50 pm
Are we just talking heater controls? You just keep the original heater and all I had to do was swap one of the control cables. On the mk6 there are 2 cables, a long one and a short one, I had to swap the short one for another long one as the controls sit slightly further to the left :D
As for the clip, I can't even remember what I done? It was a good while ago :lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: mk6 to mk7 dash
Postby tony&kasia » Wed Dec 03, 2014 12:13 am
Thanks punto for your reply. Basically when I took out the dash I took the whole lot as one unit with the heater & heater controls all still attached. I am wondering if It' possible to plug in the main heater so it all works. Or do I have to use the mk6 heater.
tony&kasia
Re: mk6 to mk7 dash
Postby Punto443 » Wed Dec 03, 2014 12:23 am
Tbh, I don't know? I just used the mk6 one, but I think there the same?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: mk6 to mk7 dash
Postby tony&kasia » Wed Dec 03, 2014 12:28 am
Would be a lot easier if it did fit. I will let you how it goes.
tony&kasia
Re: mk6 to mk7 dash
Postby jay » Fri Dec 05, 2014 11:52 am
I used mk6 heater....I also used mk6 controls as they do still fit..mk7 control will fit as well but i wanted minor things people will notice as well...not sure if mine being a executive makes a diffrence but my mk6 heater box had a extra bit of plastic each side which was for the trim which wraps round the heater to match with old dash i had to remove these bits of plastic but otherwise it fitted in place in a day... hazard switch i have still to modify same for both heated screen switchs
mk1 connect tourneo
jay
Re: mk6 to mk7 dash
Postby Punto443 » Fri Dec 05, 2014 2:12 pm
I take it the fiddly bits will be waiting a bit jay? :?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: mk6 to mk7 dash
Postby tony&kasia » Fri Dec 05, 2014 2:18 pm
I knew about modifying the hazard switch but i didn't know about the heated window switches,
tony&kasia
Re: mk6 to mk7 dash
Postby rangiep38 » Tue Dec 23, 2014 8:12 pm
I've done mine, hazard was easy haven't got round to doing the heated window switches or the wire for the headlight motors. It's just out of paint so getting built up and I'm onto the steering wheel mod which I've forgotten how to do
rangiep38
Re: mk6 to mk7 dash
Postby tony&kasia » Wed Dec 24, 2014 11:04 am
Punto has a thread about the steering wheel mod, It's worth looking it up, How did you do your hazzard switch? :)
tony&kasia
Re: mk6 to mk7 dash
Postby rangiep38 » Mon Dec 29, 2014 7:33 pm
There was a thread on the hazard switch on here, it's basically chopping both the new and old switches and gluing together
rangiep38
Re: mk6 to mk7 dash
Postby tony&kasia » Tue Dec 30, 2014 12:47 am
Yeah i have seen the thread, That is the only & best thread on here about the hazzard switch :D
tony&kasia
Re: mk6 to mk7 dash
Postby jay » Tue Dec 30, 2014 1:15 pm
I have just cut the old switch end to fit the new front bit... still need to find a mk7 heated switch..
mk1 connect tourneo
jay
Re: mk6 to mk7 dash
Postby tony&kasia » Tue Dec 30, 2014 10:23 pm
You can use a Focus C Max switch, There exactly the same, Punto told me and they are the same :D There's loads on ebay.
tony&kasia
