Transit Custom mods and 'upgrades'.
Re: Custom mods and 'upgrades'.
Postby ake » Tue Sep 02, 2014 7:34 pm
Does the custom still use the valeo fog star?
Postby Mike » Tue Sep 02, 2014 7:57 pm
ake wrote:Does the custom still use the valeo fog star?
Yessum, same as the MK7. The Osram LEDriving is designed as a direct replacement for it.
Mike
Wind up merchant!
Postby ake » Tue Sep 02, 2014 7:58 pm
How does the cornering nonsense connect up? To existing wiring?
Postby Mike » Tue Sep 02, 2014 8:05 pm
You can connect to the indicators, but a better solution on the Custom is to connect to the oem cornering light wires.
Mike
Wind up merchant!
Postby Mike » Thu Oct 16, 2014 4:04 pm
The standard stereo has always been lacking compared to what I listen to at home, but I've been happy with it until now. Anyway a visit to the local in car guru's resulted in a plan and a few purchases.
A set of JL components, to be run actively from the 2 channel amp, with the Bit Ten doing the x-over and TA duties.
Adaptors (thanks Tran59)
Audison Bit Ten and JL 4 channel amp
And a lead to avoid any cutting of the standard loom, this will allow me to take the speaker output from the HU to the high-level inputs of the Bit Ten
Also a load of Dynamat for the doors
Sub to be decided on but it's unlikely that it'll be anything big, unlike young Meghan Trainor, I don't think that it's 'All about that bass', sound quality is the most important thing. But I'm not going as mad as the crazy MK7 build of 2010!
Mike
Wind up merchant!
Postby ake » Thu Oct 16, 2014 5:58 pm
Mike wrote:The standard stereo has always been lacking compared to what I listen to at home, but I've been happy with it until now. Anyway a visit to the local in car guru's resulted in a plan and a few purchases.
I knew you wouldn't leave it alone :lol:
Postby Altransit » Fri Oct 17, 2014 8:40 pm
Like a kid with a BMX, just can't have it the way it came :roll: :P :lol: :lol: :lol:
Postby loot » Mon Oct 27, 2014 8:36 pm
Nice little van there mike 8)
Ids map here
loot
Postby Mike » Sun Feb 08, 2015 1:08 pm
Speaker wire colours from the rear of the cd player,
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
At the speaker end they're marked with paint, the LHS is marked with green (LF +) and yellow (LF -)
Mike
Wind up merchant!
Postby Mike » Sun Feb 08, 2015 4:36 pm
RHS cable markings at the speaker end are blue (RH+) and yellow (RH-).
Mike
Wind up merchant!
Postby Mike » Sun Feb 08, 2015 7:59 pm
So time for the standard speakers to go
Stuck a bit of Dynamat in the doors and an adaptor
Stuck the JL Audio mids in
Took out the stander tweeter
Which seems to take a full range feed from the head unit and filter out the lower frequencies with a capacitor
The JL tweeter is a little smaller than the Ford one, so it pops in nicely.
A couple of blobs of hot glue stops it moving
Tucked the tweeter wires out of the way
So I've taken the wires from the head unit and routed them to under the passenger seat, two pairs of wires go back to the dash, mids and tweeters. I've fitted the JL x-over for now, hoping the get the Audison Bit Ten and JL amp fitted soon.
Mike
Wind up merchant!
Postby Altransit » Sun Feb 08, 2015 8:03 pm
8) 8) :mrgreen:
Postby kulataz » Tue May 05, 2015 3:59 pm
did you get the kit finally fitted yet? Im still designing mine. Latest thoughts are
bit ten
focal 2 channel amp
cdt hd62's
focal 1 channel amp
12" type r sub under the seat.
I decided not to cut the door panels yet as I cant find a spare pair to butcher. Looks like the es06's are going to stay out for now
Graham
kulataz
Postby Mike » Tue May 05, 2015 4:48 pm
Not yet, I've been too busy enjoying myself :oops:
Mike
Wind up merchant!
Postby kulataz » Tue May 05, 2015 5:52 pm
that sounds ominous.....lol
kulataz
