Fitting a tailgate mk7
Re: Fitting a tailgate mk7
Postby shaun23 » Wed Sep 02, 2015 2:18 pm
Too many wires!
Help
Tailgate seems to have a grey plug for the central locking and a black plug for the rest.
When it comes to central locking I've actually no clue
2012 Ford Transit SWB 260 Trend 160ps
shaun23
Postby shaun23 » Wed Sep 02, 2015 2:22 pm
Still got my Mk7 rear doors lock so if it's easier to explain which wires are for what I could follow punto and modify the lock
shaun23
Postby Tango330 » Thu Sep 03, 2015 12:56 pm
I'll do some pictures of both ends so you can work it out mate. Mine are all coloured :)
T330 RWD now sold
Ford Ranger Wildtrack now sold
MI 5 sacked me from my job as an interrogator this morning, didn't like to ask why :?
Tango330
Postby Tango330 » Thu Sep 03, 2015 2:48 pm
shaun23 wrote:Still got my Mk7 rear doors lock so if it's easier to explain which wires are for what I could follow punto and modify the lock
OK Mate here we go, grey plug definitely does locking on mine. Description added as it's difficult to get a good pic which clearly shows wire colours. you'll note there's an extra black on the lock end, which I presume is the earth :?
Pic 1 grey plug looking at plug plain side, pins down, reading from left to right
Black/Brown
Black/White
White/Black
Yellow
Pic 2 grey plug, t'other side with clip, pins down reading left to right
Yellow/black
Black/Green
Green/Black
Black/Blue
Pic 3 lock end plug, purple clip on left, pins down, reading left to right
Green/Black
Black/Brown
Black/Blue
Black/White
Pic 4 lock end plug, purple clip on right, pins down, reading left to right
White/Black
Black/Green
Black
Yellow
Yellow/Black
Hope that helps. You should be able to work out which wire goes to where from the description I think :?
T330 RWD now sold
Tango330
Postby Bigfeesh » Wed Oct 21, 2015 2:49 pm
I have just finished my tailgate conversion, a pal had one he had no requirement for, the wiring was the biggest problem, burnt out the original lock! Managed to rescue the job with a spot weld onto the original lock otherwise it was £150 for a new one! Fitting LED foglights over the hinge holes from fleabay, square look ok I suppose! Thanks for all the help and ideas from this forum.
Bigfeesh
Postby Punto443 » Wed Oct 21, 2015 5:43 pm
Bigfeesh wrote:I have just finished my tailgate conversion, a pal had one he had no requirement for, the wiring was the biggest problem, burnt out the original lock! Managed to rescue the job with a spot weld onto the original lock otherwise it was £150 for a new one! Fitting LED foglights over the hinge holes from fleabay, square look ok I suppose! Thanks for all the help and ideas from this forum.
Any pics of the lights?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby loot » Tue Dec 22, 2015 9:35 pm
Some good info here, i will fit mine over xmas damn it :P
Ids map here
loot
Postby Punto443 » Tue Dec 22, 2015 10:11 pm
Got this for mine :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby loot » Wed Dec 23, 2015 10:21 am
Aw you've only got a little 1 punts, some kind of 3rd class lever arrangement?
Ids map here
loot
Postby Punto443 » Wed Dec 23, 2015 10:51 am
Nah, that ones for a mates tv cabinet I'm building :D
Still toying with the idea on the van though?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
